ecm code 13
Old Mar 19, 2003 | 05:43 PM
move_right's Avatar
Default ecm code 13
I did a search, but did not find this answer. I have the DSM 450cc injectors on my 98 GSR, and also the SMC super map controller. my turbo is not on yet. for some reason, I keep getting the ECM 13 code, which I believe is the 'baro sensor range/performance' code. why does this code keep coming back? what exactly is it from?
by the way, I would have put this in the integra section, but I figured more people in this section would have experience with it.
thanks.
Old Mar 19, 2003 | 07:18 PM
TurboDC4's Avatar
Default Re: ecm code 13 (vinny)
Im having the same problem
Old Mar 19, 2003 | 07:35 PM
BoostedSi's Avatar
Default Re: ecm code 13 (TurboDC4)
probably from that smc
Old Mar 19, 2003 | 08:32 PM
Evil EG's Avatar
Default Re: ecm code 13 (BoostedSi)
make sure wires are connected properly..
Old Mar 19, 2003 | 08:38 PM
TurboDC4's Avatar
Default Re: ecm code 13 (BVM)
Sodered together.
Old Mar 20, 2003 | 03:06 AM
move_right's Avatar
yeah, all my wires are connected well. all of them soldered and shrink wrapped.
Old Mar 20, 2003 | 05:07 AM
Flamenco-T's Avatar
reset the ecu, start at idle, put your car in 3rd or 4th gear from a dead stop, then rev it and try to drive it without stalling it, basically you're putting a load on the engine...
if it comes up again, check all wiring, if not, forget about it.,..you're fine...
baro sensor has no physical sensor nor return value, that's the only thing you can do
stan
codybuRr
Aug 14, 2012 06:48 PM
lscrxhf
Jul 4, 2006 08:08 AM
EF8 JUNKIE9
Aug 7, 2005 09:54 PM
White Lightnin
Jun 28, 2002 09:15 AM
