venom intake manifold and iacv questions
i was wondering if any one out there is running a venom or str intake manifold. if so how did ya'll run the iacv so that the car will idle correctly. if any could basically tell me how the iacv works then maybe i might be able to figure out a alternative solution to this or if you have a better solution to be able to eleminate it all together. any and all help appreciated. the sooner the better my car is idling like ****.
Re: venom intake manifold and iacv questions (EVILD16BSTD)
You have to drill and tap a few holes to mount the factory iac valve to the venom manifold. I think the STR's have the holes already drilled out the box. What kind of ECU are you running? You don't absolutely have to have an iacv to get the car to idle right. If you have a standalone ecu, there should be some idle features that let you adjust for the lack of one. I'm not running one on my car right now, and to compensate i just have my idle set a little higher at 1000rpm.
Re: venom intake manifold and iacv questions (maxpsi)
i would also like to know, cause i have a hp racing intake mani that i took off cause the car idled like sheit
-jonathan
-jonathan
Re: venom intake manifold and iacv questions (boostaholic)
as of right now I am running the stock p28 I just finish doing a fully built motor and I am still breaking it in. I was just wondering if there was a solution for the problem during break in. After break I have a AEM standalone unit that I am going to run in my car. I guess if there is no quick solution I will have to deal with it for the time being.
thanks though for the info.
Re: venom intake manifold and iacv questions (aznracer1132)
i am looking at getting a venom but i wont have a standalone for a good bit. i dont want a shaky or jumpy idle. either.
anyone have pics of what they did to get the iacv on it?
thanks
thanks
tuningrookie
01-20-2008 12:53 PM
dumbchild
16
02-27-2003 07:57 PM
Markaccord95
02-19-2002 10:04 PM
Markaccord95
02-19-2002 05:48 AM
