fuckin POS s200...HELP ME!!
****** POS s200...HELP ME!!
god damnit. well my ****** box isnt getting power now.. wtf. no led or anything i checked the wires and im gettin all ground except for 1 which im not getting anything. ive tried reseting ecu, checked fuse.. everything wtf is going on.. put dataloggin on it for a few hours this morning.. it was workin fine.. wtf
Re: ****** POS s200...HELP ME!! (BoostedH23a1)
well i dont have any power to any of the 4 leads off the ecu.. that mean ecu is shot?
Re: ****** POS s200...HELP ME!! (DR. ON POINT)
i'm also having trouble with my hondata...My CEL keeps coming on and the hondata light is blinking. John told me that I need to just wiggle it back on, but the thing just keeps on coming loose or the connection is bad(I also have the p72)...Does anyone else have this problem?
Banned
Re: ****** POS s200...HELP ME!! (qwklude82)
here is a thing that might posible work to "reset" the ECU
hold the shift button down, turn car on, run for 1 minute, turn car off, take finger off button
When the hondata is blinking it is not being connected.... pull out the ECu take the cover off and make sure its still clipped in
Make sure nothing is restricting the wire...... etc....
Check ur ******* connectins!
Don't worry dude. It sounds like a connection soldering problem. Try Dr. On Point's suggestions. I had a hell of a time trying to get my system bug free. I did eventually.
man ive tried everying besides shittin on the bastard... hmm wonder if poo is a conductor.. aha jk..
i get NO led what so ever.. it was workin fine like 5 hrs ago.. i dont know wtf is going on.
all the sodered connections are fine.. which prong has power to it on the CN3 thing
is it 1,2,3, or 4 that has power... do the rest have ground? man wtf is going on.
godmanit now i havbe to get another ECU and order more **** from hondata (they already have me for 800).. so then i can soder more **** into my p72 and have it fry a few days later again.. should of went aem.. god im a ****** tard
Banned
how u know its ur ECU?
No point of bashin Hondata.... y dont u call them and try and figure it out, they will work with u........ u got any friends u can swap hit out to see what the problem is?
i think it is the ecu not the hondata.. im just saying i have over 1500 into this setup thats why im pissed off it fried the ecu.. i think at least.. how can i check ecu.. i dont have anyone with civics or tegs.. all them have rx-7 and supras and **** like that.. to test ecu i have to buy p72 and resoder all that bullshit..
New User
nothing starts and runs a honda like a stock honda computer. thats why hondata works. Im willing to bet that ya soldering isnt good enough and maybe it was loose. It can hapen. just check everything out and then call the dealer you got ya stuff from. tell them whats up and see if they can help. If not call hondata....dont point fingers when ya not sure.
Banned
Re: ****** POS s200...HELP ME!! (simple4012)
send ur **** to Hondata.... call Doug... i spoe to him when I ha a issue, he cleared it right up...... extremely nice guy and he has a cool acccent
Check for 5V between pins 1 and 3 on the ECU. I think one is ground(black). I have the newest blue box. I tried to solder my own ECU and ended up frying it. I felt the same way as you dude, I was SO frustrated. Then my datalogging sucked, cut J12, all good. Then my laptop-serial connection sucked bad. Got the Key Span USB, all good. Keep trying.
Re: ****** POS s200...HELP ME!! (Doodoo)
u talkin about the 4 wire thing right.. well i show ground on all those.. should i get out my multimeter? do i need to have the ecu installed and do with ign. on?
do i hook it up.. turn the ignition on and take my multimeter and put the black probe to the #1 and the red probe to the #3 (dont think the color matters) but is that how u are saying do it.. or 5v for each lead...
yeah on the ECU. Pin 1 is black, Pin 3 is red when the cable is connected. disconnect it, turn the key to ign. and test with a multimeter, should be 5V.
do that in the morning...
if its not 5v then what.. bad soddering or bad ecu right
hey i found something.. i saw a resistor that is burt.. i get powere b4 it but not after... should i try radioshack.. get a new ressiter and soder it it.. the resistor color is golden... the left has a gold ring.. the center has a gold ring and 2 green rings on the right side what ohm is that...it looks to be in location R77
[Modified by BoostedH23a1, 10:27 AM 3/18/2003]
Fo-Do Fanatic
09-03-2010 04:22 PM
