how do the injectors work...clips,cc???
Old Mar 17, 2003 | 06:58 PM
ridnmyhonda's Avatar
Default how do the injectors work...clips,cc???
Ok well i need some 440 injectors and i've read about dsm and you need clips. I'm assuming to make it work with the honda. Do you need to do anything special to make it fit an aem fuel rail? i dont get how everything works....thanks
Old Mar 17, 2003 | 07:18 PM
DeepSi's Avatar
Default Re: how do the injectors work...clips,cc??? (ridnmyhonda)
With RC 440cc fuel injectors you will need the injector harness. you wont need anything special to hookup to the fuel rail, you should replace the rings, but those should have come with the fuel injectors. DSM injectors are 450cc.
Old Mar 18, 2003 | 05:11 AM
PolosportZ81's Avatar
New User
Default Re: how do the injectors work...clips,cc??? (DeepSi)
i would like to know as well.... so ur saying with RC 440cc it should be straight up plug an play? what about the dsm 450cc? i think on my 98 civic ex you will need a resistor box, but i'm not sure what to get? i would like dsm 450cc only cuz they're much much cheaper
Old Mar 18, 2003 | 06:24 AM
DeepSi's Avatar
Default Re: how do the injectors work...clips,cc??? (PolosportZ81)
With RC Injectors you need to buy the RC Injector harnesses.
With DSM 450ccs you might need to get the resistor box if you have a newer car (All Civics and Integras from 1992 and up, Preludes/Accords from 1997 and up). This should help both of you guys http://www.muller.net/sonny/resistorbox/
Keangdawizes
Oct 31, 2008 11:56 PM
jedsus
Aug 7, 2008 01:25 PM
flat-blk-HB
Jul 9, 2002 10:09 AM
