I may have quite a bit of an issue...
Old Jul 18, 2003 | 10:44 PM
Goldfingiz's Avatar
Default I may have quite a bit of an issue...
I have a 91 CRX Si with B20 turbo. Today, when I turned the car on, I heard a very loud tick coming from my valve cover. Anyway, it ends up a bolt on one of the rockers became loose, and fell off. This happened to the previous owner a couple of times, but stopped for a while. Any idea what can be causing this? I have EF-1 L21 camshafts (strong NA, wild FI: 262 duration/10.4 lift). Are they too big for the stock B20 valvetrain? I'm gonna try to secure it with locktite and hope for the best. Any ideas? I have yet to pull the valve cover, I turned the car off and it's been parked since.
Here are some pics.
Anyone know how much to tighten this?
Another angle:
Nut that goes on top:
Nut threaded onto it:
There are two things to tighten. One is a flat head screw, and the whole thing goes up and down as i tighten/losen. After that I have to thread the bolt over the screw. Anyone know the specs, or how I should go about doing this?
Any/all help is very much appreciated!
Modified by Goldfingiz at 6:02 PM 7/19/2003
Old Jul 18, 2003 | 11:14 PM
ion_four's Avatar
Default Re: I may have quite a bit of an issue... (Goldfingiz)
hmm...weirdness...I would say "RED" loctite...what bolt is it, exactly? could you replace it with a stud and double-nut it?
Old Jul 18, 2003 | 11:39 PM
Goldfingiz's Avatar
Default Re: I may have quite a bit of an issue... (ion_four)
Definitely gonna try loctite. I'm not exactly sure which bolt is yet. I guess I find out tomorrow when I pull the valve cover off =\
Old Jul 19, 2003 | 08:22 AM
Goldfingiz's Avatar
Bump...about to take the valve cover off...
Old Jul 19, 2003 | 09:02 AM
Goldfingiz's Avatar
Pics added Sorry about the quality!
Old Jul 19, 2003 | 09:21 AM
romeo619romeo's Avatar
im guessing some1 has tighten it down whiel the motor was still warm...try to get a new nut from honda and replace it back on with the motor absolutely cold
Old Jul 19, 2003 | 09:23 AM
Goldfingiz's Avatar
Default Re: I may have quite a bit of an issue... (romeo619romeo)
Any idea how to adjust the valve? Specs?
Also, do I adjust to stock spec with these cams?
Modified by Goldfingiz at 6:46 PM 7/19/2003
Old Jul 19, 2003 | 09:51 AM
Phaze2 Mike's Avatar
youll need the specs for the cams in the particular motor, look on the cams site. Also, do NOT start the car like that, the valve could bend and destroy the head if your lucky, the motor if your not.
Old Jul 19, 2003 | 09:54 AM
Goldfingiz's Avatar
Default Re: I may have quite a bit of an issue... (Nextekhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nextekhatch &raquo;</TD></TR><TR><TD CLASS="quote">youll need the specs for the cams in the particular motor, look on the cams site. Also, do NOT start the car like that, the valve could bend and destroy the head if your lucky, the motor if your not. </TD></TR></TABLE>
Willks has the feeler gauge but he's sleeping!
Carmine said he'll probably be up between 3-4. =\
Take my *** to AutoZone fool!
Old Jul 19, 2003 | 11:58 AM
Goldfingiz's Avatar
I think I have to gap .0004 and .0005, but every feeler gauge I find starts at .0008. Does anyone make a gauge that starts at .0004?
Old Jul 19, 2003 | 01:22 PM
boostaholic's Avatar
.0004 is really small, might want to double check that lash setting. I use a Snap On valve lash adjusting tool, works like a charm. Looks like this:
Old Jul 19, 2003 | 01:45 PM
sporkcrx's Avatar
Default Re: (boostaholic)
How much is that tool? Does that flathead push in and out?? That's freiken awesome.
Old Jul 19, 2003 | 03:45 PM
SuperTeg95's Avatar
Default Re: (sporkcrx)
Do not use loctite on that nut!! You don't want it to stick. I beleive it is to be tightened to 14lbs when cold. Im not 100% sure though on the torque.
Old Jul 19, 2003 | 05:31 PM
Goldfingiz's Avatar
Default Re: (SuperTeg95)
Are you sure not to use locktite? I'm probably doing it tonight so any help would be very much appreciated!
Old Jul 19, 2003 | 09:08 PM
Joseph Davis's Avatar
Default Re: (Goldfingiz)
Replace nut and rocker arm, not just the nut. If it has a history of this, I wouldn't trust the parts.
Any old LS garbage someone has laying around should do.
azzazel_9
Oct 5, 2018 03:47 PM
Tim_EG
Sep 20, 2012 03:12 AM
si90rex
Sep 15, 2011 07:21 AM
