Math check on a AFC hack
Old Jul 17, 2003 | 10:24 AM
Sinner's Avatar
Default Math check on a AFC hack
I have 310cc injectors and I been running very rich. So rich my math sensor would give me a CEL. I just bumped it down to -15 straight across. Does this sound close? I'm watching my A/F and I always in the rich. btw There is no local dyno in my POS two. Otherwise I would be there, but now I have to make the drive there without screwing up my car.
Nick
Old Jul 17, 2003 | 10:26 AM
twkdCD595's Avatar
Default Re: Math check on a AFC hack (Sinner)
I asume you mean MAP sensor?
Old Jul 17, 2003 | 12:08 PM
psileepR's Avatar
New User
the larger the negative number the more you lean it out. if u bumped it down to -15 you probably richened and going the wrong direction. lean out until your a/f doesnt read rich all the time.
with 310's i think your should be trimming about -30
Old Jul 17, 2003 | 03:01 PM
ion_four's Avatar
Default Re: Math check on a AFC hack (Civtek)
We can all review our algebra together... (and my goddamned spelling)
.40/450 = X/310
(.40/450)*310 = X
X = ~.28
So, trim out about -30%...
Old Jul 17, 2003 | 05:02 PM
Sinner's Avatar
thank you very much.
Nick
Old Jul 17, 2003 | 05:05 PM
spike's Avatar
Default Re: (Sinner)
I didn't think you could run the hack with 310's.
Old Jul 17, 2003 | 05:54 PM
Bailhatch's Avatar
Default Re: (spike)
Isn't "the hack" just hooking up the AFC and instaling larger injectors? So esentialy even if your injectors were stock 280 injectors (for example) and you put in 285s and leaned it out just 1or 2% with an AFC then you are running "the hack".
Old Jul 17, 2003 | 06:02 PM
spike's Avatar
Default Re: (Bailhatch)
no i believe it is trimming out enough of the MAP voltage that the ecu does not see "boost" .. this is why it will throw a CEL if you try to richen it up too much. With the 310's you need to run a value closer to 0 than -50 and when it boosts I think the ECU will freaking when it sees a MAP voltage out of the range it can handle.
Old Jul 17, 2003 | 07:49 PM
Sinner's Avatar
i got it at - 20 right now. its a little rich but until I get to the dyno. I gotta be safe.
Nick
Old Jul 17, 2003 | 07:52 PM
Mr.DC2TurBo's Avatar
-20?? I think u have it wrong.. Should be around -40 to -30 b/c any less will throw a cel. I think you forgot to set your in/out sensor to 6 instead of 1.
mikevar94
Mar 13, 2014 06:56 AM
pa2play
Jun 27, 2004 12:16 PM
turboegg
May 2, 2003 04:32 AM
Hellz99si
Sep 23, 2002 05:20 PM
dwilson
Jun 5, 2002 04:49 PM
