Yet another a/f and boost gauge question...
I just purchased a set of used autometer boost and a/f gauges however, the wires are rather short. Is there a certain gauge wire that I should use to extend it or does it really matter? Also, the boost gauge's power and ground wire are larger so I am assuming I will need a thicker gauge wire than the a/f gauge(if that makes sense ). Thanks in advance for any help.
I was wondering the same thing.. I have a a/f gauge with single strand small small wires (dont know the exact size). Will it matter if I use a slightly bigger multi-strand wire to extend them?
Not trying to thread-jack, our questions are pretty much the same thing.
Re: Yet another a/f and boost gauge question... (boostedcivicsir)
I guess what i'm really worried about is the o2 signal wire for the a/f gauge. IS it a special kind or can I just get the same size wire to run it?
Mr. Badwrench
Re: Yet another a/f and boost gauge question... (braintree)
i think the wire off the gauge is like 20 or 22 ga. i have 16 ga lying around and used it. worked fine you should be ok.
potatostix
03-30-2006 10:02 PM
Voodooboy520
12-03-2005 03:59 PM
