front mount intercooler
Old Jul 16, 2003 | 12:15 AM
jdmacura's Avatar
Default front mount intercooler
i was wondering what you guys think i should do. i am running 5 psi boost i was wondering if you guys think i should put a FMIC on my custom turbo set-up
Old Jul 16, 2003 | 01:51 AM
InTeGrA B18b1's Avatar
Default Re: front mount intercooler (jdmacura)
yes do it it helps
Old Jul 16, 2003 | 03:39 AM
BROOD's Avatar
Go for it it is not a bad idea.
Old Jul 16, 2003 | 06:39 AM
CRXRageD's Avatar
If you intend to run that low amount of boost, you can get a small intercooler. If you intend to boost more. I would go with an intercooler that gives you some latitude.
Old Jul 16, 2003 | 08:51 AM
jdmacura's Avatar
does it matter on the dimension of the intercooler?
Old Jul 16, 2003 | 08:59 AM
quikB18B's Avatar
Default Re: (jdmacura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmacura &raquo;</TD></TR><TR><TD CLASS="quote">does it matter on the dimension of the intercooler?</TD></TR></TABLE>
Yes first decide how much power you ultimately plan on making so you can get a FMIC that will effecient for the power youneed to support. A good candidate would be maybe a spearco unit, or try ebay boostcollers sells kits from like 325-450 depeding on size. go with something of this sort 26.5x7x3.
Hope this helps.
Old Jul 16, 2003 | 09:22 AM
jdmacura's Avatar
Default Re: (quikB18B)
im going to run 5 psi boost on stock internals do you think this size would be okay?
Core size: 30 X 6 X 2
Tanks: 2.125 wide X 7 high X 3.25 deep
Piping: 2.5 OD X .0625 wall X 2.25 long
Old Jul 16, 2003 | 09:34 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Having a intercooler is always good idea. I'm running 5psi too.
Let me see if I can find the specs on it. I just know its was the maxrev intercooler .. which I was told used a HKS core with maxrev endtanks.
Does anybody know the size of that intercooler?
Old Jul 16, 2003 | 11:56 AM
mike1114's Avatar
Default Re: (Snafu-Si)
This wil be just fine. (I would get one thicker than 2 inches though.)
Something to consider to is aesthetic appeal. I like an intercooler that almost fills up the bottom grill of my 97 civic completely.
I got mine off ebay from auction1010. It was 31X6X2.75
Old Jul 16, 2003 | 01:00 PM
quikB18B's Avatar
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote"> im going to run 5 psi boost on stock internals do you think this size would be okay?
First let me say that it too big for your setup. How much is this btw? "30 inch lenght core size" thats big. No need to spend $ where you dont need it. Also get something thicker than 2 inches. When i was in market for mine the ebay ones were going for $335 for a 26.5x7x3 this is end tank to endtank not core size.
I ended up getting a precision FMIC for $350 its 26.5x6.5.3.5 and core size i believe is 18.5x6.25x3.5, this is plenty enought to support my goal of 275-290 whp.
torqueless
Jul 2, 2006 09:55 AM
91glassycrx
May 7, 2004 12:26 PM
Arsenal
Oct 13, 2003 06:55 AM
blacksi00
May 15, 2003 08:46 PM
phase12gsr
Apr 23, 2002 01:18 PM
