Critique setup please
Old Jul 16, 2003 | 10:09 AM
Pfieff's Avatar
Default Critique setup please
All of this will be going on an '00 d16y7 w/30k miles
Greddy turbo kit @8-10psi
Greddy type 31 FMIC
Greddy Type S BOV
Greddy profec B
440cc injectors
hondata s100b
guages- boost,egt, fuel pressure
Any items you would add? Will the stock fuel pump be ok? Thanks,
Pfieff
Old Jul 16, 2003 | 10:10 AM
BROOD's Avatar
Default Re: Critique setup please (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">
I would add a fuel pump and an adjustable fpr to your set-up.
Modified by SLPR at 11:44 AM 7/16/2003
Old Jul 16, 2003 | 10:11 AM
Pfieff's Avatar
I didnt' think there was a need for a fpr with the hondata, correct if i'm wrong
1dumbscreenname's Avatar
Default Re: Critique setup please (SLPR)
fuel pump
Old Jul 16, 2003 | 10:12 AM
Pfieff's Avatar
255 high out or just the regular 255?
Old Jul 16, 2003 | 10:18 AM
rygan21's Avatar
did anyone say turbo timer? or does hondata do all that? if money doesnt matter id also get a greddy oil cooler and a new head gasket
Old Jul 16, 2003 | 10:26 AM
rygan21's Avatar
ohh and id get a fluidyne radiator and some colder sparkplugs
Old Jul 16, 2003 | 10:38 AM
Default Re: (rygan21)
the walbro is what I have and I also have NGK bkr7e plugs gapped to .040. people on this board have their plugs gapped to .030 but my car ran like crap at that gap.
Old Jul 16, 2003 | 10:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rygan21 &raquo;</TD></TR><TR><TD CLASS="quote">did anyone say turbo timer? or does hondata do all that? if money doesnt matter id also get a greddy oil cooler and a new head gasket</TD></TR></TABLE>
you dont need the timer if you dont mind sitting in your car for an extra minute before shutting down, and summit sells oil coolers for our apps for way less than the greddy. mobil 1 10w30 is the oil I use and it works well with turbos.
Old Jul 16, 2003 | 10:42 AM
Pfieff's Avatar
dumbass, do you have the high pressure output one or the regular 255?
Old Jul 16, 2003 | 10:44 AM
Default Re: (Pfieffdog)
I have the walbro 255lph pump and it works great
Old Jul 16, 2003 | 11:01 AM
dabrown's Avatar
Default Re: (1dumbassscreenname)
Just for clarification because I need to know, do you really need another fuel pump with 8-9 psi? Wouldn't the factory be enough with the 440's? I am doing a similar setup except for a SOHC and I was advised that the Fuel pump was not needed...
Thanks
Old Jul 16, 2003 | 11:04 AM
Default Re: (dabrown)
I would upgrade the pump also for the fact that you have how many miles on the old pump and it certainly wont hurt. I think pushing 9 psi does require a new pump though and big injectors will push more fuel
Old Jul 16, 2003 | 11:11 AM
dabrown's Avatar
Thanks,
My car only has 60,000 and how often do Fuel Pumps go bad? I am trying to avoid excessive fuel dump..
Old Jul 16, 2003 | 11:15 AM
gritsak's Avatar
ide just get the pump...better safe then sorry...and about the excessive fuel dump that what you have a regulator and tune for
Old Jul 16, 2003 | 11:23 AM
Pfieff's Avatar
I know that walbro makes a 255lph and a 255lph HP, which one should I go with?
Old Jul 16, 2003 | 11:49 AM
dabrown's Avatar
Pfieffdog, who is tunning your car? If it's a hondata recommend shop inquire about the fuel pump. I know it doesn't hurt but if your like me Money is TIGHT&gt; I am trying not to spend anymore for my initial $3500 Setup on a $1100 Kit....
Old Jul 16, 2003 | 02:08 PM
Pfieff's Avatar
GruvyTune will be tuning the car. I'll shoot him an email and see what he says.
Pfieff
Old Jul 16, 2003 | 06:32 PM
the FMU will not allow there to be excessive fuel dump, get the pump, any 255lph pump will so, i suggest the walbro.
Old Jul 16, 2003 | 08:51 PM
Pfieff's Avatar
My hondata tuner said that the stock fuel pump should be ok, any other opinions on the setup?
Old Jul 17, 2003 | 04:59 AM
Pfieff's Avatar
ttt
jit01
Oct 29, 2006 05:25 AM
JDM turbo DC
Nov 8, 2005 05:51 PM
95turbohatch
Feb 1, 2004 06:33 PM
2000Si-at-UK
Apr 2, 2002 07:23 AM
TurboSedan
Oct 4, 2001 06:53 AM
