11.2:1 compression and a supercharger
Old Jul 18, 2003 | 07:51 AM
xonn's Avatar
Default 11.2:1 compression and a supercharger
My compression check is yielding 200 psi across the board. I'm considering running 5 psi or so of boost on it. What are your thoughts,concerns, comments?
Old Jul 18, 2003 | 08:47 AM
Walker0904's Avatar
do it, that is what im planning on doin, high compression + boost = insane power, that is an equation that cannot be disproved, its a law...high compression = more power period. you'll make great power with that kind of comperssion, just make sure you tune it well..
Old Jul 18, 2003 | 09:29 AM
trbob16a's Avatar
Default Re: (Walker0904)
I am a big fan of high compression plus boost. In this case, I would recommend away from it if you are going with a roots style blower. Without the intercooler, that is a lot of heat to be dumping in with that compression. I think you will have a hard time keeping away from detonation. I'm not saying it isn't possible, but either way you could make more power with a properly tuned turbo setup for the same cost.
Old Jul 18, 2003 | 10:05 AM
GreddySi99's Avatar
Default Re: (trbob16a)
at 5psi the blower wont make that much heat go ahead and do it! it will make good power with good engine management
Old Jul 18, 2003 | 10:27 AM
xonn's Avatar
Default Re: (intercooledJRSC)
I'm thinking I'm going centrifugal if anything. With 11.2:1 compression, 5 psi should be good for at least another 40 to 45 or so at the wheels... I'm making 189 at the wheels now so another 40 would be most welcome
Old Jul 18, 2003 | 12:02 PM
stierhund's Avatar
Default Re: (xonn)
get a blockguard for cheap, and tune it well, and go vortech
will make great power
sxysweed
Jan 6, 2010 05:14 AM
95civhb
Jan 4, 2010 01:49 PM
slowcrx954
Nov 23, 2006 07:49 AM
b18c5turbo
Jul 15, 2005 02:51 PM
TehMoonRulz
May 16, 2005 01:15 PM
