Think I got into trouble w/this turbo. (vafc, timing, & int. wastgate ?'s)T3 turbo
Hey guys I need some help. I will be installing the turbo next week if everything arrives on time (otherwise the week after for sure). Im getting really worried. Oh yeah by the way, if Dynomax is reading this, hey, are you busy next week?
My question is this.
I have a .60/.48 60 trim T3 turbo and will be using the int. wastegate. I believe the stock wastegate is set at 10psi. I believe this is too much for my D16z6 right from the start. I know I need to change the spring to lower the boost. Do you know anywhere that sells different springs for my wastegate on my T3?
If not, what are some settings I can set my VAFC to in order to run considerably rich so I dont lean out?
Also, what should I retard my timing to in order to protect my engine?
Setup:
t3 turbo
starion FMIC
450cc injectors on the "hack"
2.5 DP and 3 inch exhaust
2.25 to IC and 2.5 to throttle body
Thanks a lot!
Dan
Setup:
t3 turbo
starion FMIC
Thanks a lot!
Dan
Re: Think I got into trouble w/this turbo. (vafc, timing, & int. wastgate ?'s)T3 turbo (racinskittle
Thanks a bunch! I really appreciate the help.
LOL now i can FINALLY get some decent sleep instead of thinkin about that at night.
Modified by racinskittle at 5:07 AM 7/19/2003
check out thedropshop.tv/vafc they have a little article about it with some helpful pics
hoya_10fintec
06-12-2003 06:21 AM
