cometic head gasket question..
Old Jul 16, 2003 | 08:18 PM
Wide Open Throttle's Avatar
Default cometic head gasket question..
first of all, i searched and didn't really find what i was looking for.
has anyone run the .078 cometic HP head gasket?
Cometic said that this gasket lowers compression by about half a point on a stock B18C1. is this accurate? is this gasket reliable?
thanks
Old Jul 17, 2003 | 10:26 AM
Default Re: cometic head gasket question.. (Wide Open Throttle)
Old Jul 17, 2003 | 10:28 AM
PM-Performance's Avatar
i tihnk it lowers it by mroe thna 1/2 a point , the .43 was like 1/2 pt, the .78 is closer to 3/4 to full point
Old Jul 17, 2003 | 10:40 AM
LSiTurbo's Avatar
Default Re: cometic head gasket question.. (itr206)
i personally wouldnt go to big on the headgasket. leave it be...
Old Jul 17, 2003 | 10:46 AM
Default Re: cometic head gasket question.. (LSiTurbo)
thats what i say too , i stuck with the .30
Old Jul 17, 2003 | 08:20 PM
are they reliable (the .078)?
Old Feb 24, 2004 | 05:49 PM
Slick GS-R's Avatar
BACK FROM THE DEAD!
does anyone have any experiences with these thicker gaskets? i'm very close to purchasing one!
thanks guys
Old Feb 25, 2004 | 11:24 AM
Slick GS-R's Avatar
Default Re: cometic head gasket question.. (Slick GS-R)
bump
Old Feb 25, 2004 | 11:37 AM
the thickest i have seen from them is .43, they dont list thicker in their catalogs
Old Feb 25, 2004 | 11:41 AM
Slick GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Cometic's MLS (Multi-Layer Steel) Gaskets
These are constructed of two nitrile coated outer embossed spring steel layers with a steel inner layer that provides support to the gasket allowing multiple thicknesses. Cometic gaskets withstand the shearing forces created by aluminum heads on cast iron blocks. Once the gasket takes a torque set, there is no re-torquing required. Less clamping force is required allowing for reduced bore distortion.
Cometic HP Style head gasket
These gaskets have an extra shim around the combustion area to help seal better for cars with turbo, nitrous or supercharger.
Cometic MLS Gasket
Thickness: 0.025”, 0.030”, 0.040”, 0.054”
Thickness: 0.067”, 0.078”
Thickness: 0.098”, 0.120”
Cometic HP Gasket
Thickness: 0.036”, 0.043”, 0.057”
I found this sheet online ... does anyone have any experiences that they can share with the thicker gaskets? I'm purchasing a .054" very soon!
Thanks
Old Feb 25, 2004 | 11:51 AM
for Hondas i have only seen , .30, .36, .43
from what i heard Inline Pro uses Cometic gaskets with their name on it . I dunno how true it is, but thats what i heard.
Also if you go that thick you will need to tune cam timing , becuase the timing will change alot.
Old Feb 25, 2004 | 06:50 PM
blueturbo4door's Avatar
i am a dealer for cometic and the thickest they make the HP gasket is 0.057. They are very good gaskets and i personally have the 0.057 HP on my car.
Old Feb 25, 2004 | 07:01 PM
Eg4-TuRbO's Avatar
Default Re: cometic head gasket question.. (blueturbo4door)
how about the greddy 2mm gasket? how much does that lower it by? i have that on my car
Old Feb 25, 2004 | 07:27 PM
TeamCracka's Avatar
Default Re: cometic head gasket question.. (Eg4-TuRbO)
Just to try and clear it up a little ...
I have the Cosmetic HP 0.057" headgasket and it lowers my JDM B16A compression by 0.751:1 over the stock 0.029" headgasket.
Anyone know roughly how much this will effect timing?
byohnd
Nov 14, 2005 08:07 AM
.::Lee::.
Feb 17, 2004 08:50 PM
