Turbo Manifold Temperature
Old Jul 17, 2003 | 12:06 AM
Fatty_1775's Avatar
Default Turbo Manifold Temperature
How hot do your manifolds get? Is it supposed to be really hot, even if you've been driving for less then an hour? Thanks.
Old Jul 17, 2003 | 12:49 AM
Foozball26's Avatar
Default Re: Turbo Manifold Temperature (Autobot_Killer)
lol mine gets super hot after driving it for 2 mins, its just the nature of exhaust gases
Old Jul 17, 2003 | 04:11 AM
Farnsrocket's Avatar
Default Re: Turbo Manifold Temperature (Foozball26)
Yeah, like 1400 degrees F.
Old Dec 10, 2003 | 08:21 AM
integra-modder's Avatar
Default Re: Turbo Manifold Temperature (Farnsrocket)
im curious too....
The stock exhuast manifold didnt melt the dip stick....this inline pro unit melted my dip stick and is causeing oil to fly out and go all over my engine bay.
I dont know if it could be that my timing is retarted , but its set to 16~19 at idle.
anyone know what the temps of the runners should be? I used a heat gun and it read 440~480 at idle.
Old Dec 10, 2003 | 08:53 AM
Foozball26's Avatar
Default Re: Turbo Manifold Temperature (integra-modder)
if you're melting **** you may think about getting the manifold jet hot/ceramic coated.
Old Dec 10, 2003 | 09:00 AM
Johnyquest's Avatar
Me and my friend (drag mani, greddy mani respectively) both melted our dipsticks. heat comes with the territory, my friend!
Old Dec 10, 2003 | 09:43 AM
Default Re: Turbo Manifold Temperature (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">Me and my friend (drag mani, greddy mani respectively) both melted our dipsticks. heat comes with the territory, my friend!</TD></TR></TABLE>
what have you done to prevent it/keep it under control?
Old Dec 10, 2003 | 10:25 AM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">im curious too....
anyone know what the temps of the runners should be? I used a heat gun and it read 440~480 at idle.</TD></TR></TABLE>
thats where mine is at... driving the freeway @ 80mph and not in boost mine get to about 800 C.
another intersting fact is how fast it cools down after you shut off the engine.... it goes from 600+ C to below 400 C in like a min.
Old Dec 10, 2003 | 10:30 AM
30psi Teg's Avatar
I believe like 900 deg F is typacal for just highway crusing at like 2k-2.5k rpm under high load you should get around 1200-1300 deg F maybe even 1400 but I think if I remember like 12-1300 is optimal.
Old Dec 10, 2003 | 01:41 PM
Default Re: (30psi Teg)
if 1200-1300 is optimal...how does anyone manage to keep their stock tip stick without melting the seals?
Old Dec 11, 2003 | 10:27 PM
Default Re: (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">if 1200-1300 is optimal...how does anyone manage to keep their stock tip stick without melting the seals?</TD></TR></TABLE>
ttt
Old Dec 11, 2003 | 10:35 PM
99B16Si's Avatar
mine did the same...makes a mess and it kinda smells sometimes
Old Dec 12, 2003 | 11:33 PM
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">mine did the same...makes a mess and it kinda smells sometimes</TD></TR></TABLE>
nasty smell and blue smoke....but i think i kinda got to liking it after having to drive with it for 2 hours
Old Dec 13, 2003 | 04:18 PM
baphomet's Avatar
you mean oil was coming out of the dip stick tube - how do you fix this if the dip sticks keep melting - plug?
Old Dec 14, 2003 | 03:57 PM
Default Re: Turbo Manifold Temperature (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">
you mean oil was coming out of the dip stick tube - how do you fix this if the dip sticks keep melting - plug?</TD></TR></TABLE>
Im considering cutting the tube down a bit so that its not right between the two runners rather a few inches below.
Old Dec 14, 2003 | 04:04 PM
TRE_'s Avatar
mine gets really hot even if its just idling, but its never melted anything...
Ek4 life
Sep 28, 2008 06:05 PM
Finland
Apr 15, 2005 09:27 AM
mrbsponge
Sep 16, 2004 11:42 AM
Charlie Moua
Oct 24, 2003 08:41 AM
BoostedITR41
Aug 27, 2003 11:29 PM
