BLITZ DUAL turbo timer and boost gauge
Old Jul 17, 2003 | 12:31 PM
JrCRXHF's Avatar
Default BLITZ DUAL turbo timer and boost gauge
Has anyone used this timer on a Honda if so how hard was it to hook up and how well did it work? Can you find directions on how to install this timer?
Old Jul 18, 2003 | 03:02 PM
iiilgsrlll's Avatar
Default Re: BLITZ DUAL turbo timer and boost gauge (JrCRXHF)
I used to have it on my Integra and it worked pretty well. I liked it because its also a boost gauge in addition to being a timer. Hookup is very easy. I believe there are 4 wires on the main harness (red, blue, green, and black) and a few on the secondary harness. I remember that the purple wire on the secondary harness HAS TO be grounded for the unit to work correctly. Red is obviously power and black is ground. I played with the solder points on the ignition column until it worked correctly. I don't remember the right wire combinations at the moment but someone else probably does. You'll be happy with it though. Just remember boost is displayed in BAR.
GDM Z28
Feb 27, 2004 07:00 PM
SuperpooV
Dec 3, 2003 05:05 PM
shadowdawn
Apr 2, 2002 12:49 PM
