jrsc problem with surging motor
Old Jul 17, 2003 | 04:57 PM
94jaxgsr's Avatar
Default jrsc problem with surging motor
Need a little help. Just installed a jrsc and when ever i start the car it seems to serge over and over again at idle. Running a 8lb pulley, jr fmu, aem fpr, stock injectors. Has anyone ran in to this problem before? If so what should i do? It looks like the engine wants to jump out of the car. Any input would really help me. Thanks
Old Jul 17, 2003 | 05:29 PM
96IntegraRS's Avatar
Default Re: jrsc problem with surging motor (94jaxgsr)
My first guess is definitely a vacuum leak... any weird noises along with the "surging"?
Old Jul 17, 2003 | 05:35 PM
94jaxgsr's Avatar
Default Re: jrsc problem with surging motor (96IntegraRS)
No strage noises that i can hear. I have an exhaust leak so i cant really hear anything else to well. Im pretty sure that i hooked all the hoses up right. The car is also idleing at 1500 rpms. I tried to ajust the idle on the throttle body but it stays at 1500.
Old Jul 17, 2003 | 05:56 PM
Do you have a boost gauge in yet?
Old Jul 17, 2003 | 06:00 PM
94jaxgsr's Avatar
No not yet putting it in this weekend so i dont know what boost i am at. Thats probably not helping is it. I also have a jr timing controler in.
Old Jul 17, 2003 | 06:15 PM
gitwidit's Avatar
I made the stupid mistake of not putting my pcv valve back in one time..... Surged bad and smoke a little.
Old Jul 17, 2003 | 06:21 PM
The boost gauge is a way to confirm that you do or don't have a leak... the motor should idle around -20 psi (at normal idle) - if it's signifigantly higher, you would have a leak.
I had the same problem when I installed mine - it was a crappy seal between the blower and the manifold, but it made a horrible whistle.
Old Jul 17, 2003 | 06:26 PM
94jaxgsr's Avatar
I will be working on it tomorrow. And also getting the exhaust fixed and proabably the guage. I will let you know where i am. Thanks for all the help
Old Jul 17, 2003 | 06:37 PM
jabroni95gsr's Avatar
weird...i have a whistle under load in a high gear and at low rpms....but it sounds like the same whistle that was there before the charger from the iceman intake.
also, my boost guage will read between -20 and -25 depending...sometimes its -20, other times -25....
Old Jul 17, 2003 | 07:30 PM
Default Re: jrsc problem with surging motor (jabroni95gsr)
That whistle is from the throttle body - my car does the same thing at part throttle... actually sounds like a turbo spooling...
The horrible noise I was talking about was a huge leak between the blower and the manifold 0 it was so loud that you couldn't hear the engine running with the hood off - obviously fixed that.
Old Jul 17, 2003 | 09:47 PM
RuffGsR's Avatar
-Any one ,
Mine is making a wierd noise, but only after 5000 RPMs...
It sound like it is the belt, but I'm not sure.
Old Jul 18, 2003 | 05:05 AM
Default Re: jrsc problem with surging motor (RuffGsR)
Are the bearings in the tensioner pullies OK?
Old Jul 20, 2003 | 05:20 PM
94jaxgsr's Avatar
well thanks for the help figured out the surging problem. Forgot to put the pcv hose on. all fixed now.
Old Jul 20, 2003 | 08:16 PM
gitwidit's Avatar
Default Re: jrsc problem with surging motor (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">I made the stupid mistake of not putting my pcv valve back in one time..... Surged bad and smoke a little. </TD></TR></TABLE>
Glad to help anytime
blue00sifun
Jul 4, 2006 10:05 PM
DeDonDeRosa
Dec 3, 2005 07:54 PM
larryd
Oct 11, 2004 07:06 PM
91civicEX
Jun 14, 2004 12:07 PM
vtecsiqt
Apr 23, 2002 09:03 PM
