whats needed with a vafc?
Old Jul 15, 2003 | 04:32 PM
RudeLude's Avatar
Default whats needed with a vafc?
if i use a vafc for fuel, do i need an fmu or anything else? i'm planning on using some dsm450's and resistor box. any help would be much appreciated.
thanks
daniel
Old Jul 15, 2003 | 05:13 PM
siboi18's Avatar
Default Re: whats needed with a vafc? (RudeLude)
you won't need the fmu at all....toss it. Why not save up for hondata?? With that it will be like 100x better
Old Jul 15, 2003 | 05:14 PM
RudeLude's Avatar
Default Re: whats needed with a vafc? (siboi18)
what about a fuel pump? will the stock one do?
Old Jul 15, 2003 | 08:16 PM
RudeLude's Avatar
i know there are alot of vafc hacks on here, someone please answer me.
Old Jul 15, 2003 | 08:21 PM
twkdCD595's Avatar
Default Re: (RudeLude)
type in v-afc hack in the search box and if you cannot find AT least 6-10 threads about this I will be VERY suprised.
I whipped this dead horse not to long ago myself.
no fmu.
always good to have too much fuel pump as opposed to not enough... my opinion ditch the stock.
only other thing you need is a map signal hack or map/ check valve setup.
Old Jul 15, 2003 | 08:22 PM
twkdCD595's Avatar
Default Re: (twkdCD595)
just checked the recent topics and there was 2-3 pages of results similar to the follwing.
Your search for v-afc hack returned the following 23 results.
» New Search
Topic Forum Date Posts
problems boosting with the hack...
Forum » Forced Induction
Creator » jz 8:07 PM 7/15/2003
by jz 11
Runnig GM 3 bar map with vafc hack YES or NO
Creator » NOSED_CRX_VTEC 12:27 PM 7/15/2003
by shermanyang 5
Integra owners with S-AFC...
Creator » redtegger03 7:11 PM 7/14/2003
by civicguy 3
:: vafc hack users :: is anyone still using the smc plus or 500? post reviews here ::
Creator » ID_ten_T 5:41 PM 7/14/2003
by TeStUdO 3
can u put injectors in without a hack?
Creator » egturbo 3:21 AM 7/14/2003
by egturbo 4
s-afc setting on ls
Creator » jdm2916 5:44 PM 7/13/2003
by jdm2916 1
CEL Code 13 (Baro Sensor) V-AFC Hack
Creator » Sivik 3:39 AM 7/13/2003
by Sivik 14
low boost hesitation with v-afc hack?
Creator » othick 7:42 PM 7/11/2003
by scttydb411 8
turbo gsr vafc hack question
Creator » 2001teggsr 2:02 AM 7/11/2003
by Type-GS-R-Turbo 2
afc hack q
Creator » ha illuminato un 9:48 PM 7/10/2003
by scttydb411 4
94 GSR IN A 94 CIVIC HB WITH A VORTECH CHARGER WITH VAFC HACK
Creator » FLATBLKCIVHB 5:49 PM 7/9/2003
by FLATBLKCIVHB 28
Those with VAFC hack... did you connect the blue wire??
Creator » Sivik 12:14 AM 7/9/2003
by Sivik 5
vafc hack ?'s
Creator » ek96 11:44 PM 7/8/2003
by ek96 1
vafc hack
Creator » ha illuminato un 5:36 PM 7/8/2003
by ha illuminato un 9
need help on hoooking up a apex i s afc spec 2
Creator » TURBO B 4:23 PM 7/8/2003
by 2BAR4ME 3
confused about hack.
Creator » 2SLO 3:56 AM 7/5/2003
by kpt4321 9
Info: Ford Probe GT 2.2 Liter injectors 310cc with Fields Boxer SFC-VTEC controller hack.
Creator » Sinner 1:05 PM 7/4/2003
by bluedelsol 4
READ: V-AFC hack + 440 Injectors +3 Bar Discovery ( 1 2 3 ... 7 )
Creator » Type-GS-R-Turbo 9:29 AM 7/4/2003
by rjardy 206
h-t afc hack info ( 1 2 3 ... 8 )
Creator » liam821 5:43 PM 7/3/2003
by Sohc Driver 221
running very rich with hack.. please help
Creator » queez 9:01 AM 7/3/2003
by VTC_CiViC 15
Fields SFC-VTEC hack?!
Creator » 2SLO 12:06 AM 7/3/2003
by 2SLO 15
How would i set this up? Fuel Hack
Creator » bluedelsol 9:19 PM 7/2/2003
by bluedelsol 1
B&M FPR with the AFC hack? Is it going to be a problem?
Creator » fnananon 12:26 AM 7/2/2003
by shermanyang 7
seanjohn81
Jan 23, 2007 04:46 PM
silverbulletgsr
Dec 24, 2003 12:46 PM
ggangtong81
Aug 29, 2003 12:20 PM
Blackcivic1
Jul 22, 2002 03:24 PM
autoEXturbo
Jul 18, 2002 05:03 AM
