Is this cause by the delta wastegate????
Old Jul 17, 2003 | 08:42 PM
Fired Honda's Avatar
Default Is this cause by the delta wastegate????
I was running VAFC + 370cc Drag turbo.
Anyways, while running for a test drive my boost guauge stop at 4psi and it start to sputter, boost could not go any further. I currently had a turbonetic delta wastegate.
1) Is this cause by the stupid turbonetic wastegate?? My wastegate is 7psi and It no where I think that what cause this problem.
2) could it be a boost leak? Well I check all my pipe but nothing wrong..
Any help appreciated...thanks
Should I upgrade to Tial wastegate?? heard lots of good thing about Tial...
Old Jul 17, 2003 | 08:47 PM
InTeGrA B18b1's Avatar
Default Re: Is this cause by the delta wastegate???? (Fired Honda)
do you have a fmic? its boost drop from the ic and your probaly leaking boost
Old Jul 18, 2003 | 12:37 AM
g2ls_turbo's Avatar
i have a 7psi spring in mine and it boost no more than 6psi. i know mine has a leak on my manifold flange. its a leak for sure. check the manifold to head, and turbo flange to manifold.
Old Jul 18, 2003 | 05:42 AM
shermanyang's Avatar
Default Re: (g2ls_turbo)
my deltagate wg busted open on me 3 weeks ago...thought i fixed it and took it to the tracks and the center shaft busted in two!! i was shooting out of the fully open wg down the track!! POS deltagate!!
DelSolMarine
Apr 17, 2022 10:21 AM
Boosted00
Jan 19, 2018 01:51 PM
ghettochild
Sep 19, 2004 07:21 PM
turbo se
Jun 13, 2003 11:33 AM
Lei Siew Long
May 12, 2002 05:43 PM
