wastegate or boost controller?
Old Apr 11, 2004 | 10:19 AM
b00stedbyFastrax's Avatar
Default wastegate or boost controller?
i have a tial 40mm wg with a 15lb spring. on the low setting i can only get 17 psi and on the high setting i would only get 23psi. changed out the spring to a 20lb and still i can only get 23 psi. is the wg bad or the boost controller?
Old Apr 11, 2004 | 10:56 AM
vtec.dc2's Avatar
Default Re: wastegate or boost controller? (b00stedbyFastrax)
i think its your overall exhaust setup, i'm running 4.5lbs spring, but it woudn't go past 3.5lbs. i'm running 2.5" exhuast with a cat, maybe if i upgraded to 3" and removed the cat it would actually hit 4.5lbs.
Old Apr 11, 2004 | 11:09 AM
Default Re: wastegate or boost controller? (vtec.dc2)
i have a 3" DP. open exhaust
rbecue
Jun 16, 2005 03:03 AM
Harassing Herbs
Mar 1, 2004 08:31 PM
yusoslo
Jul 12, 2003 08:01 PM
shingles
Jan 24, 2003 01:58 AM
wonny
May 30, 2002 03:18 PM
