help!! is this wastegate hooked up correctly?
Old Apr 11, 2004 | 02:24 PM
TurboBumblBee's Avatar
Default help!! is this wastegate hooked up correctly?
just bought this car from my roommate as some of you know.. not sure the wastegate is hooked up right.. take a look at these pics and let me know..
thanks
Tial wastegate, Drag Manifold, Greddy Profec b spec 2..
Old Apr 11, 2004 | 02:33 PM
boosted_dc2's Avatar
Default Re: help!! is this wastegate hooked up correctly? (Boostfedb18c1)
the top port goes to the boost control solenoid, and the botom one goes to a vacum source after throttle plate.
Landon
Old Apr 11, 2004 | 04:07 PM
Default Re: help!! is this wastegate hooked up correctly? (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">the top port goes to the boost control solenoid, and the botom one goes to a vacum source after throttle plate.
Landon</TD></TR></TABLE>
ok thanks.. i looked over the manual and it looks like it might be correct..
it is hooked like this..
top of wastgate to the boost solenoid then from the other side of the solenoid it goes to a 3 way T and goes to the bottom of the wastgate and to the turbo housing..
do i need to have both the top and bottom ports hooked up?? if i dont need both the top and bottom hooked to this solenoid, where does the other port go to? thanks
Old Apr 11, 2004 | 06:26 PM
no you need bolth with an EBC you have it right the way you said. you might want to move the line from the turbo port to your intake manifold though.
Landon
Old Apr 11, 2004 | 06:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">no you need bolth with an EBC you have it right the way you said. you might want to move the line from the turbo port to your intake manifold though.
ok thanks.. now if i move the line going into the turbo how do i block off the port on the turbo??
btw, im getting a vacuum manifold this week and hope to clean up the engine bay a little more and have the vacuum lines cleaned up.. if anyone has pics or diagrams of vacuum manifolds installed, please let me see them. thanks
Old Apr 11, 2004 | 06:55 PM
Haberdasher's Avatar
Does that Greddy unit use a solenoid or a stepping motor?
Old Apr 11, 2004 | 07:13 PM
Default Re: help!! is this wastegate hooked up correctly? (Haberdasher)
the greddy is a solenoid and you can block off the turbo with a vacum plug, or you can unscrew the fitting and buy a plug for that.
Landon
Old Apr 12, 2004 | 07:53 AM
RyanEJ8's Avatar
The most accurate boost reading is through the manifold since you lose boost through the intercooler and piping. Putting it on the turbo will cause the wastegate to open up too early.
Old Apr 12, 2004 | 11:03 AM
Default Re: help!! is this wastegate hooked up correctly? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">The most accurate boost reading is through the manifold since you lose boost through the intercooler and piping. Putting it on the turbo will cause the wastegate to open up too early.</TD></TR></TABLE>
ok thanks.. im gonna reroute all the vacuum hoses once i get the vacuum manifold.. any pics of manifolds and how they are hooked up to the vacuum source, ie line to this, line to that, and etc..
Old Apr 12, 2004 | 11:26 AM
PM-Performance's Avatar
heres my vac manifold set up . you can see the big line coming off the intake manifold going to the vac block and then all the port from there. the one port goes back to the brake booster. basically the unit goes inline with the brake booster line
Old Apr 12, 2004 | 11:42 AM
Default Re: help!! is this wastegate hooked up correctly? (itr206)
ok thanks itr206.. so its basically like a distribution block for an amp.. 1 big wire in, lots of little smaller ones out.. and i feed any item that needs a vacuum signal from that distribution block, for example wastegate, bov, boost guage, boost controller...
Old Apr 12, 2004 | 11:58 AM
pretty much so . . yea
Old Apr 12, 2004 | 12:02 PM
accordfreak's Avatar
make sure that solenoid doesn't vibrate or anything.. it seems to be very fragile
I don't what caused mine break but here it is. hopefully yours won't do the same
https://honda-tech.com/zerothread?id=782447
crazy_ls_90
Oct 2, 2008 05:28 PM
Boosted2K
Sep 10, 2004 01:40 PM
sway892
May 26, 2004 10:37 AM
highmilehatch
Oct 15, 2003 07:44 AM
MayhemSi
Sep 6, 2003 11:47 AM
