ALTC wire and hondata?...
Old Apr 9, 2004 | 12:46 PM
GDM Z28's Avatar
Default ALTC wire and hondata?...
hondata talks about cutting this wire if you have alot of voltage fluxuation (sp?). they say if you cut this wire the voltage will stay at a constant voltage. has any one else heard of this or have the done it? if so wheres the wire? any info on this is apreciated. TIA
Old Apr 9, 2004 | 01:16 PM
Mase's Avatar
Default Re: ALTC wire and hondata?... (civicflnum1)
yup, i was the very first person to discover and do this
i clipped it on the obd2-obd1 harness
Old Apr 9, 2004 | 01:34 PM
GDM Z28's Avatar
Default Re: ALTC wire and hondata?... (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">yup, i was the very first person to discover and do this
i clipped it on the obd2-obd1 harness</TD></TR></TABLE>
did it work ok? everything is fine? my car is obd1 so i dont use the harness. do you know where it would be on the normal obd1 harness?
Old Apr 9, 2004 | 02:30 PM
Mase's Avatar
you have to find the pin out for the obd1 ecu, i dont know off hand.
also if you have the s200 you can disable the ELD which should also take care of it
Old Apr 9, 2004 | 02:38 PM
VTC_CiViC's Avatar
Thanks for hosting the question for me Trent! (Work filtering sux!)
One of the few sites I still have access to is Hondata and I noticed Doug talking about voltage surges and cutting that wire, but you're telling me that basically the ELD function correct? If that's the case then I have the option to disable that in Uberdata which when I did use, I noticed the GSR drove INCREDIBLY smoother.. thanks Mase.
Old Apr 9, 2004 | 03:52 PM
Big Teggie's Avatar
I had the same problems with the voltage jumping around.
Cutting the ATLC wire fixed it
Old Apr 9, 2004 | 10:40 PM
jonnybravo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">you have to find the pin out for the obd1 ecu, i dont know off hand.
also if you have the s200 you can disable the ELD which should also take care of it</TD></TR></TABLE>
Will this work on a S100?
spooncivic01
Sep 1, 2015 03:22 PM
dth0ng69
Sep 13, 2010 01:31 PM
GReddy_Civic
Engine Management and Tuning
Sep 13, 2008 06:04 AM
Pfieff
Dec 2, 2003 11:45 AM
