Dropping .2 liters...
Old Apr 11, 2004 | 10:46 PM
Smokinsax's Avatar
The Boot
Default Dropping .2 liters...
Right now im running a b20b vtec and I am planning to go turbo. So the B20 has weak sleeves blah blah blah ect...so I'm going to be changing out the block for a B18B in preperation for boost. Some people are telling me that its as simple as changing out the blocks and replacing the head gasket. I know all my oil lines will swap right over, but do I need to worry about the dowle/guide pins, cause they have already been worked to take the b20 block...
Modified by Smokinsax at 2:09 AM 4/12/2004
Modified by Smokinsax at 3:02 PM 4/12/2004
Old Apr 12, 2004 | 09:21 AM
blueturbo4door's Avatar
Default Re: Dropping .2 liters... (Smokinsax)
you are correct everything will swap over. just get a new headgasket and i would also recommend a new timing belt, water pump, and oil pump, and timing belt tensioner. then you will be all set.
Old Apr 12, 2004 | 01:04 PM
Smokinsax's Avatar
The Boot
bump...just want to make sure
19dabeast85
Honda CR-V & Element
44
Jul 31, 2014 06:44 PM
albertodsa
15
Jan 21, 2011 12:48 PM
Steven.
Aug 19, 2008 04:45 PM
RTW DC2R
Jul 2, 2004 07:07 AM
Rob!
May 10, 2004 07:22 PM
