enough fuel?
Old Apr 11, 2004 | 02:36 PM
91SIR's Avatar
Default enough fuel?
I just got my motor built and turbo installed. I have crower cams, 8:5:1 compression pistons, t3/t4 turbo, fuel pressure regulator and high flow fuel rail,walboro 255 fuel pump . I need to get it to the dyno. Would it be ok to drive if i just bumped the fuel pressure with the fuel mods i have now or would it lean out still?
Old Apr 11, 2004 | 03:38 PM
crxturboh22's Avatar
Default Re: enough fuel? (91SIR)
pull out ur spark plugs and look if they're black (rich) or white (lean) at the bottom....... how much you boosting ??? 5-7 should be okay with all u got....
Old Apr 11, 2004 | 06:29 PM
91SIR's Avatar
Default Re: enough fuel? (crxturboh22)
i just put the spark plugs in, haven't even run it since then. they are the bkr7es-11's(2 step colder i think?). Also it would be at 7psi
Silvertc
Sep 23, 2010 09:49 AM
s0flyy56
Aug 3, 2008 02:53 PM
YoungKadafi
Apr 1, 2007 04:43 PM
csm84
Sep 28, 2004 12:47 PM
PM-Performance
Jan 30, 2004 01:16 AM
