Will a hone fix this?
Old Apr 10, 2004 | 03:07 PM
Mad Cow's Avatar
Default Will a hone fix this?
*CLICK THE PICTURES TO SEE THEM FULL SIZE*
Also, do the pistons have any markings on them to indicated wether or not they are oversized? I measured the bore, and the bore seems to be 3.200in... which, according to the helms is the oversized size.
Old Apr 10, 2004 | 03:11 PM
torr's Avatar
Default Re: Will a hone fix this? (MadCow)
you can hone it if you cannot feel those scratches. if you can feel them, then you would bore it.
Old Apr 10, 2004 | 04:11 PM
PrecisionH23a's Avatar
Take your fingernail and scratch it perpendicular to the vertical marks. If it catches on a scratch, you may need to move to a larger bore. Sometimes you can get lucky and a hone will fix things, but you will be running some loose tolerances.
Old Apr 10, 2004 | 04:35 PM
Hoosier Daddy's Avatar
Default Re: Will a hone fix this? (PrecisionH23a)
What they said Looks pretty normal to me.
Old Apr 11, 2004 | 11:48 AM
Mad Cow's Avatar
Ok, so what are my options? I can feel the scratches with my fingernails (don't know if I'd say they "catch" on the scratches) so I suppose it needs a bore. Pistons are already oversized stock pistons...
raverx3m
Jun 10, 2014 10:55 AM
dritan
Jan 7, 2011 07:18 AM
rich7777
10
Feb 25, 2010 11:58 AM
speedycrx
Nov 26, 2007 07:15 PM
