Wich muffler? (searched)
Old Apr 9, 2004 | 11:27 AM
darylfiend11's Avatar
Default Wich muffler? (searched)
I have a 92 honda prelude h23. I plan on turboing, I want the exhaust to come out of the side like right in front of the back wheel. Which muffler do you guys reccomend for this setup i perfer a quiet one and would you suggest 2.5 or 3 inch piping?? Thanks
Old Apr 9, 2004 | 11:34 AM
yellowturbo's Avatar
just use 3 inch piping it will be quiet.
Old Apr 9, 2004 | 11:39 AM
Default Re: (yellowturbo)
which muffler would you suggest? i would preffer something that would go inline with the old exhuast's center section.
Old Apr 9, 2004 | 11:46 AM
KTeller8's Avatar
Default Re: (darylfiend11)
go for a 3" inlet outlet
like N1, or Es oval style ones...
something not so "flashy but still peforms"
Old Apr 9, 2004 | 11:53 AM
Default Re: (KTeller8)
will those be able to fit under the car?
Old Apr 9, 2004 | 01:30 PM
scatuli's Avatar
bump would like to know also
Old Apr 9, 2004 | 03:32 PM
scatuli's Avatar
Default Re: (scatuli)
bump
Old Apr 9, 2004 | 06:16 PM
92HB_HB's Avatar
i just picked up a dynomax 3" muffler.. looks beefy.. hopefully it will sound good w/ my 3" resonator as well...
Old Apr 9, 2004 | 06:18 PM
Ben Huynh's Avatar
Default Re: Wich muffler? (darylfiend11)
5Zigen 80mm Turbo Muffler - Best Flowing Muffler Period
Old Apr 10, 2004 | 06:07 AM
Bailhatch's Avatar
Default Re: Wich muffler? (ben@importparts.com)
Where exactly is this muffler going to go? If the exhaust comes out in front of the rear wheel you will not be able to fit much more than a resonator or an n1 style fart can. You will, however, be able to blow exhaust at peoples shoes.
I beat a cobra with his exhaust coming out in front of the rear wheels. He should have killed me so apparenty this exhaust routing makes your car really slow. just some solid tech for you to digest ....no extra charge.
Old Apr 10, 2004 | 08:14 AM
Default Re: Wich muffler? (Bailhatch)
Would any of these setups be quiet though is the main thing. Ive gotten a couple muffler tickets already and i can't afford anymore.
Old Apr 10, 2004 | 05:16 PM
If i use a n1 coming out by the back wheel with no cat i think that would be pretty loud. What can i do to make a quiet setup that is going to work.
Old Apr 10, 2004 | 05:56 PM
Hoosier Daddy's Avatar
magnaflow
Old Apr 10, 2004 | 07:02 PM
ndogg's Avatar
Default Re: Wich muffler? (Hoosier Daddy)
where is the muffler gonna be located? and wont the exhaust be like 1" off the ground to fit under the "sideskirt"? i run a side exit in front of the front tire and its not any louder than when i was NA with a full exhaust.
Old Apr 10, 2004 | 07:18 PM
Default Re: Wich muffler? (ndogg)
the exhaust would be right in front of the back wheel so a huge fart can wouldn't be able to fit
Old Apr 10, 2004 | 07:30 PM
Magnaflow's Avatar
Good Luck. The only muffler you will be able to reasonably fit underneath there would be a resonator. If you put a traditional muffler (Especially a round can) it will hang low and scrape everywhere...
Old Apr 11, 2004 | 01:34 PM
KTeller8's Avatar
Default Re: (Magnaflow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magnaflow &raquo;</TD></TR><TR><TD CLASS="quote">Good Luck. The only muffler you will be able to reasonably fit underneath there would be a resonator. If you put a traditional muffler (Especially a round can) it will hang low and scrape everywhere...</TD></TR></TABLE>
you could fit a 4" round.. maybe a tad bigger.. something like the tanabe or some other smaller , skinny version
Old Apr 11, 2004 | 02:37 PM
rocket_R's Avatar
is that legal to have the exhuast coming out from the side?
Old Apr 11, 2004 | 05:09 PM
Default Re: (rocket_R)
no it isnt but its ok
Old Apr 11, 2004 | 11:25 PM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">magnaflow </TD></TR></TABLE>
mrchris1979
Sep 23, 2009 01:49 PM
TB123
Mar 8, 2007 06:50 PM
point5pnoi
Feb 3, 2007 04:11 PM
HondaH22A
Feb 7, 2003 04:49 AM
