timing question/problem..plz help
Old Apr 12, 2004 | 01:11 PM
queez's Avatar
Default timing question/problem..plz help
k i have a b16a2 timing on cams and all seemed to be correct. all lines matched up perfectly top to bottom on belt. car idles, but when i go to get a reading with my timing light i cant seem to get a correct one. i am hooked up to wire 1 ( the left most wire) and even with the gun set at 0 and distributor pushed furthest away i cant get anywhere near 16degrees... can anyone help me.. what could be off?? i know my timing belt and everything is lined up.. so i'm just lost.. any ideas ??
Old Apr 12, 2004 | 01:13 PM
1point7T's Avatar
Default Re: timing question/problem..plz help (queez)
you have it hooked up to the wire farthest from the distributor, that's the #1...
Old Apr 12, 2004 | 01:22 PM
queez's Avatar
Default Re: timing question/problem..plz help (1point7T)
i'm sorry yeah i mean the right most wire.. furthest away from distributor ... i misprint earlier..
Old Apr 12, 2004 | 04:50 PM
queez's Avatar
up.. no one with any idea's?
Old Apr 12, 2004 | 05:21 PM
boosted hybrid's Avatar
Did you jump the CEL connector under the dash? If not, that could be an issue, more so with stabilizing the idle when checking the timing.
If you arent able to get the timing marks to line up correctly you may have skipped a tooth. If it drives really sluggish, the cam timing if off.
Old Apr 14, 2004 | 01:09 PM
queez's Avatar
Default Re: timing question/problem..plz help (boosted hybrid)
hey jefff. i got my timing to 12 degrees. everything seems to be fine. just need a boost controller.. so let me know as soon as possible when yo ucan tune me.. schedule me in..
76 camaro car
May 17, 2011 12:00 AM
northemt88
Mar 15, 2008 12:57 AM
matbh22a
Jun 19, 2007 12:15 PM
DC_RaceR
Aug 24, 2006 06:45 PM
Etylorcen
May 26, 2002 07:30 PM
