Temporary fix for oil feed?
Old Apr 9, 2004 | 12:21 PM
MikeMAN's Avatar
Default Temporary fix for oil feed?
Hey all, yesterday when i started up my car..i noticed that somehow a hole was worn through the SS jacket of my braided feed hose. Is there anything i can use to temporary patch this up? i was suppposed to drive home this weekend, but now im screwed.
lemme know,
mike
Old Apr 9, 2004 | 12:26 PM
tgreaves's Avatar
Default Re: Temporary fix for oil feed? (MikeMAN)
If you could find a union fitting or something like that you could cut the line there and install the fitting.. I wouldnt trust anything else since you know what will happen if the line leaks really bad..
Old Apr 9, 2004 | 12:29 PM
tgreaves's Avatar
Default Re: Temporary fix for oil feed? (tgreaves)
Now that I think about it you could go to home depot or somewhere like that and build a union joiner with barbed fittings.. Im not sure what size your oil feed line is but if you get the correct sized barb fitting and use hose clamps on them you should be fine..
Old Apr 9, 2004 | 12:48 PM
sporkcrx's Avatar
How big is the hole? Just a pinhole? If I was you I'd just put some tape around it until a new one arrives (you did order one right? ) Duct tape wrapped around it nicely would hold back most of the oil I would think.
Old Apr 9, 2004 | 12:55 PM
MikeMAN's Avatar
goddamnt..why didn't i think of cutting the line and getting a barbed fitting...im a dumbass....
mike
Old Apr 9, 2004 | 01:03 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">goddamnt..why didn't i think of cutting the line and getting a barbed fitting...im a dumbass....
mike</TD></TR></TABLE>
Thats what im here for
Old Apr 9, 2004 | 01:04 PM
tgreaves's Avatar
Default Re: Temporary fix for oil feed? (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How big is the hole? Just a pinhole? If I was you I'd just put some tape around it until a new one arrives (you did order one right? ) Duct tape wrapped around it nicely would hold back most of the oil I would think.</TD></TR></TABLE>
Errr.... That line is under pressure.. I don't think duct tape will hold it but I might be wrong.. Either way I still wouldn't do it..
Old Apr 9, 2004 | 01:13 PM
T-RO's Avatar
OR you could run to an auto parts store and buy a section of "hardline" (used for brakes) and just use that. You can bend it by hand and it cost less than $5
Old Apr 9, 2004 | 01:27 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Errr.... That line is under pressure.. I don't think duct tape will hold it but I might be wrong.. Either way I still wouldn't do it..</TD></TR></TABLE>
yea, I have some epoxy putty in there right now, used for marine leaks and oil leaks, however the problem with stainless braided hose, is that the braided surface is slightly above the rubber. So if you close the leak, it just moves up the line...I will see how this crap works, if it doesn't..im off to cutting the line and getting some unions.
BTW: i dont have a dremel up at school, what would be the best way of cutting the line??
mike
Old Apr 9, 2004 | 01:32 PM
tgreaves's Avatar
You can use a set of bolt cutters.. I have used them before and they work pretty good..
Old Apr 9, 2004 | 01:33 PM
tgreaves's Avatar
Is this feed line for a ls vtec or for a turbo.. Even if you fix it I would still get another one just to be safe..
Talk to Stan(Flamenco-T) on here and he'll fix you up..
Old Apr 9, 2004 | 01:35 PM
MikeMAN's Avatar
turbo, and yea..im not one to ghetto rig things..i OVER do things(which is why im SUPER pissed)...I have a feed line from one of stans kits i bought a while ago. I just PM'd him to see if it will fit on the stock greddy banjo bolt thingy...
Old Apr 17, 2004 | 06:14 PM
hotintegranights's Avatar
same thing happen to me spent all day trying to fix it, i tried some many different stuff on it, epoxy,jb weld, nothing work cause it kept leaking from another side of the braided steel, but was not as bad so it got me home, tomorow i will try the barb fittings inbetween the lines i think thats your best bet also
Old Apr 19, 2004 | 07:30 PM
MikeMAN's Avatar
Default Re: Temporary fix for oil feed? (hotintegranights)
barb fittings wont work, the line is metal underneath...damn you GREDDY!
mike
philafelman
Nov 4, 2009 06:21 PM
Black R
Feb 20, 2005 03:12 PM
beepy
Mar 1, 2004 09:26 PM
reignofchaos
Jul 27, 2003 10:34 AM
C1V1CS1
Oct 16, 2002 12:23 PM
