precision sc61 too big?
Old Apr 9, 2004 | 11:56 AM
B18 CYA's Avatar
Default precision sc61 too big?
Hey all, got a GSR engine with 9 to 1 je pistons...81mm , Eagle H beam rods and blockguard, 550 injectors and ready to go turbo. Found a good deal on a SC61 precision turbo. Has an upgraded T04 S compressor cover which has a 4 inch inlet with 2.5 inch outlet compared to the regular 3-inch inlet and 2-inch outlet. Would this turbo be too big for my gsr and take too long to spool up? Any suggestions on what to change for my setup? Thanks
Old Apr 9, 2004 | 12:07 PM
FOrSfEd's Avatar
Default Re: precision sc61 too big? (c2nap)
Spool time would be pretty laggy but after it starts power will be great depending on how much hp you plan to make. What kinda power do you plan to make.
Old Apr 9, 2004 | 12:43 PM
B18 CYA's Avatar
Default Re: precision sc61 too big? (FOrSfEd)
plan on running 12-15 hp and hopefully getting 300-350 hp... how bad will the lag be?
Old Apr 9, 2004 | 12:48 PM
1RS2NV's Avatar
12-15hp? u mean psi?
I have a garrett t4 and it kicks in at 4500.
JDM_Risa's Avatar
i am planning on getting a sc61 too.......you will be fine at 12-15lbs of boost i think 350 is achievible easily since the turbo supports much more then that....
how much are you getting your sc61 for.......
i want a lovefab equal length SST manifold with a sc61
is it too big? its never big enough hahahaha
Old Apr 9, 2004 | 12:52 PM
FOrSfEd's Avatar
Default Re: precision sc61 too big? (GunMETAL_TEgRa)
Mine starts to spool around 4200 so your would prob be a lil higher prob right around 4500. But I think you will be happy with the outcome.
Old Apr 9, 2004 | 12:55 PM
B18 CYA's Avatar
awesome...yeah i meant 12-15 psi not hp ...fat fingers haha Im getting it for 500 ...buddy of mine locally. Anyway, do you have other suggestions I shall do to my engine to support all that? should i sleeve the block? i know its gonna cost a lot
Old Apr 9, 2004 | 01:01 PM
B18 CYA's Avatar
also, still gotta buy a turbo manifold. will a custom or no name brand one work or is there really a diff between them and the brand name ones such as revhard or inlinepro or revmax?
Old Apr 9, 2004 | 01:24 PM
B18 CYA's Avatar
anyone?
Old Apr 9, 2004 | 01:27 PM
FOrSfEd's Avatar
Default Re: (c2nap)
Depends if you want equal length or log style. If I were you I would go with a inlinepro manifold. Sleeving would def help out.
Old Apr 9, 2004 | 01:49 PM
TurboJesse
Guest
Posts: n/a
Default Re: (FOrSfEd)
if all you want is 350whp i would look into a different turbo.
Old Apr 9, 2004 | 01:57 PM
tthame1's Avatar
Default Re: (Mpir3)
SC61 T350 76 Trim w/ a TO4E Compressor housing would probably be good for that setup b/c that is what Precision recommended to me with similar hp goals, but being a T04 w/ the S comp housing, that will probably be too big.
Old Apr 9, 2004 | 02:28 PM
ndogg's Avatar
Default Re: (tthame1)
i think sleeving would be overkill for 350hp. if you have an extra grand laying around then go for it, otherwise you should be ok without.
Old Apr 9, 2004 | 02:31 PM
tthame1's Avatar
Default Re: (ndogg)
That's what I was thinking. I wouldn't sleeve unless your hp goals are over 400
Old Apr 9, 2004 | 02:33 PM
FOrSfEd's Avatar
Default Re: (ndogg)
I would agree that the turbo is big for that goal but for 500 you can spare the extra lag it will produce. And everyone knows as I that you have a goal and once you reach it you want more. So I do believe the turbo is the right choice and sleeving is great to have. You can never hand enough security when it comes to building an engine. I've seen engine go with less than 200 hp.
Old Apr 9, 2004 | 02:45 PM
RZFD's Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">if all you want is 350whp i would look into a different turbo.</TD></TR></TABLE>
Word. For $500 bucks pick it up, resell it and go for a T3 and Hondata.
Old Apr 15, 2004 | 10:53 PM
jeremy.'s Avatar
Default Re: (RZFD)
up
Old Apr 15, 2004 | 11:02 PM
SiRkid's Avatar
Default Re: (ek_jeremy)
the S housing wont effect spool time that much really.
you should hit full boost at about 5000 rpm(with a .63 a/r)
you should start seeing some boost by 3500 rpm .
if you dont mind that, buy it and use it..
howmuch is a "good deal"
from arturbo its like 750 us NEW for any of the precision sc series.
so like 1100 cad (with shipping).
1.8tgsr
Jan 20, 2005 01:44 PM
EKB18BPR3
Jul 14, 2004 03:32 PM
SPOON_BeIgHtEeNsEe
Jan 28, 2004 05:17 PM
Mr. Softee
Jul 17, 2003 09:05 AM
LudeyKrus
Apr 19, 2003 03:36 PM
