Help..First time tapping a oil pan
Old Apr 11, 2004 | 04:21 PM
CATCH DIS HATCH's Avatar
Default Help..First time tapping a oil pan
can anyone give me some points on tapping a GSR oil. What to do? where to drail? fitting? welding? ................etc
Old Apr 11, 2004 | 06:41 PM
Vtec92Civic's Avatar
Default Re: Help..First time tapping a oil pan (CATCH DIS HATCH)
1. put your turbo and manifold on your block if you have them and imagine running a rubber hose a steel braided line from the return side straight to the oil pan
2. mark the spot in which you want to drill (drill as high as possible still allowing the fitting you are using to fit)
3. you can either force thread the fitting which is just use a wrench to screw in, weld a fitting, or JB Weld It, or you can tap the hole to screw the fitting in
4. you are done . . . takes a little bit of time but that's it.
Old Apr 11, 2004 | 06:51 PM
B18Flip's Avatar
Default Re: Help..First time tapping a oil pan (Vtec92Civic)
and make sure you have the DP and even the IC piping in when you mock it up.....i didn't and ended up having to redo it
Old Apr 11, 2004 | 06:58 PM
Charles B.'s Avatar
Default Re: Help..First time tapping a oil pan (B18Flip)
pic courtesy of fast-turbo.com
Old Apr 12, 2004 | 08:59 AM
-Trinitron-'s Avatar
You are supposed to tap near the top of the deepest part of the pan. You are also supposed to tap in front of one of the caps so the windage from the rotating crank doesn't affect the drain flow.
Old Apr 14, 2004 | 08:50 PM
Danger's Avatar
problem solved
Modified by JonnyDanger at 4:44 PM 4/16/2004
mikej94civex
Feb 28, 2016 05:44 AM
MalcolmV8
Dec 5, 2011 05:29 PM
AF-b16a1
Aug 3, 2004 02:24 PM
RedStarGsr
Dec 25, 2003 10:21 PM
Evil EG
Apr 3, 2002 07:30 PM
