Which timing belt to use for this setup?
Old Apr 8, 2004 | 09:21 PM
TheSwift1's Avatar
Default Which timing belt to use for this setup?
I searched, but I couldn't find an answer..
I'm using a 99 B16 head on a 97 GS-R bottom end...which timing belt and water pump should I use??
Old Apr 8, 2004 | 11:54 PM
1.8turbolsvtec's Avatar
Default Re: Which timing belt to use for this setup? (TheSwift1)
used the gsr or a b16 there are the same
Old Apr 9, 2004 | 12:14 AM
R THIS's Avatar
Default Re: Which timing belt to use for this setup? (1.8turbolsvtec)
you have to use the same timing belt as the water pump...
b16 water bump = b16 timing belt
gsr water pump = gsr timing belt
Old Apr 9, 2004 | 12:21 AM
OTOKOTO-TSOI's Avatar
i would use the GSR instead.
Old Apr 9, 2004 | 01:32 AM
turbohonda's Avatar
Default Re: Which timing belt to use for this setup? (OTOKOTO-TSOI)
The B16 timing belt won't work on the B18 blocks, reguardless of of the head. The deck height is shorter on the B16 block. The B16 and GSR water pumps are the same. They both have 22 teeth that the belt rides on. Use the Gsr timing belt and water pump.
Old Apr 9, 2004 | 04:58 PM
blueturbo4door's Avatar
Default Re: Which timing belt to use for this setup? (turbohonda)
yep, gsr or b16 water pump but you have to use the gsr timing belt.
Old Apr 9, 2004 | 06:17 PM
TheSwift1's Avatar
ok..so i can use the B16 water pump and a GS-R timing belt? darn...i had bought a B16 timing belt, but never used it..guess i'll have to sell it now..
what's the advantage of the GS-R pump vs. the b16?if any..
Old Apr 9, 2004 | 08:01 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8turbolsvtec &raquo;</TD></TR><TR><TD CLASS="quote">used the gsr or a b16 there are the same</TD></TR></TABLE>
um..no
Old Apr 10, 2004 | 01:46 AM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohonda &raquo;</TD></TR><TR><TD CLASS="quote">The B16 timing belt won't work on the B18 blocks, reguardless of of the head. The deck height is shorter on the B16 block. The B16 and GSR water pumps are the same. They both have 22 teeth that the belt rides on. Use the Gsr timing belt and water pump.</TD></TR></TABLE>
hatchet_honda
Apr 11, 2009 11:16 AM
918-Hatch
10
Feb 21, 2007 12:19 PM
94sol
May 4, 2006 06:00 PM
del slw
Feb 1, 2006 04:02 AM
turboekcivic
May 23, 2005 06:58 AM
