engine builder suggest this....
Old Apr 10, 2004 | 01:48 PM
respectblades's Avatar
Default engine builder suggest this....
my friends engine builder suggested a 10-0 compression for his gsr build
he plans on run 15 to 16 psi on the track
its getting new dart sleeves by the way
isn't this compression a little high..
usually when i read about a turbo setup in a magazine the compression is a little lower....
Old Apr 10, 2004 | 01:53 PM
ekb18c's Avatar
Default Re: engine builder suggest this.... (respectblades)
Don't believe everythign you read in the mags.
10:1 compression is just fine for that amt of boost on pump gas.
BTW - It's 10:1 compression not 10:0
Old Apr 10, 2004 | 01:57 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: engine builder suggest this.... (ekb18c)
Nothing wrong with a 10:1 setup with a sleeved and built motor, talk to your tuner also and see what he says, since he will hold the fate of your motor
Old Apr 10, 2004 | 02:58 PM
earl's Avatar
Default Re: engine builder suggest this.... (SIXTYdashONE)
you guys might want to ask him if he is running pump gas or race gas and what his engine mgmt plans are.
Old Apr 10, 2004 | 03:05 PM
HT's Biggest Loser
Default Re: engine builder suggest this.... (earl)
I was hinting towards that by suggesting his tuner
Old Apr 10, 2004 | 03:07 PM
ekb18c's Avatar
One would only assume that he's running some kind of fuel management system (Not FMU) sinces he's spending money on sleeves etc..
Well then again it's not really psi that we should be judging by, it should be hp.
So what fuel managment system are you going to run and what hp level you are trying to achieve?
Old Apr 10, 2004 | 03:22 PM
nigel's Avatar
10:1 is an awesome cr for boost. I have seen some sick numbers out of 10:1
depending on the tuner you can make 450+ with the right turbo and fuel system
Old Apr 10, 2004 | 04:48 PM
danl's Avatar
Banned
Default Re: (nigel)
Why stop at 10:1 and 15 psi. Run 13:1 and 5 psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by respectblades &raquo;</TD></TR><TR><TD CLASS="quote">my friends engine builder suggested a 10-0 compression for his gsr build
Thats infinitley low compression so you can run infinitley high boost.
Old Apr 10, 2004 | 05:01 PM
xenocron's Avatar
Default Re: (danl)
danl, i see a lot of your posts and dont ever let anyone call you conservative!
Seems the right people have chimed in on this thread. 10:1 i think is a respectable amount of compression. Much of depends on how 'safe' or 'extreme' you want to be with your setup.
Seems alot of people are conservative with their builds these days (8.5:1 pistons, sleeved block, 14 psi and a 11.5-12 AFRs). Its kind of a waste IMO to run such a nice setup and not tune it to its true potential.
I say be bold! And if the tuner you go to seems scared of the compression ratio...find another tuner or learn to do it yourself (much more fun in my opinion ).
Old Apr 11, 2004 | 08:49 AM
Default Re: (xenocron)
he's going with the aem system.....
and he's shooting for about 400 hp
using the drag gen 3 kit
Old Apr 11, 2004 | 08:54 AM
DaveF's Avatar
Default Re: (respectblades)
id rather be able to run more boost on a lower compresion ratio, than run less boost on a high compresion engine.
the boost will make more power than the extra points of compresion.
Evolsport
Jul 17, 2009 12:44 PM
CXtypeR
Feb 28, 2007 10:44 PM
Drizzo
Aug 16, 2005 02:00 PM
flip1199
Aug 11, 2004 08:10 PM
1boostedgsr
Mar 6, 2004 04:45 PM
