Easy Air Filter Solution even in tight spaces!
Old Apr 8, 2004 | 12:47 PM
-iLLuZioN-B18C1's Avatar
Default Easy Air Filter Solution even in tight spaces!
I was originally having lots of problems trying to get my filter to fit in the small spacing that i had in the bay. After trying to buy some 90 degree mandrel bend from Kteller and it still not fitting correctly, I looked at the apexi filter solution using the rubber hosing and came up with my own.(well, sort of)
1 3" to 3" rubber hosing at home depot
and whatever size K&N filter you can almost think of at:
http://www.performanceintl.com/shop/kn.cgi
cut part of the rubber hosing off since the opening actually flares out to almost 3 1/2"
then screws right up.
that rubber hose isnt gonna melt on me or anything is it??
Old Apr 8, 2004 | 01:06 PM
Finest's Avatar
Default Re: Easy Air Filter Solution even in tight spaces! (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
that rubber hose isnt gonna melt on me or anything is it?? </TD></TR></TABLE>
I would double check the heat range on that rubber thing. The compressor housing can get quite hot.
Old Apr 8, 2004 | 04:54 PM
Charlie Moua's Avatar
Default Re: Easy Air Filter Solution even in tight spaces! (98CTRCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">
I would double check the heat range on that rubber thing. The compressor housing can get quite hot. </TD></TR></TABLE>
ditto not to mention the "edge" of that filter!
team714
Dec 26, 2007 01:02 PM
skylinevo
Jul 7, 2006 08:47 AM
K20Death
Aug 1, 2005 05:17 AM
86si
Jun 4, 2005 11:26 AM
Nextelbuddy
Jun 10, 2004 04:39 PM
