who makes speed/gear based boost controllers
Old Apr 12, 2004 | 11:13 AM
jeremy.'s Avatar
Default who makes speed/gear based boost controllers
anyone know if a gear based boost controller is worth it? what brands make them or come as a option?
Old Apr 12, 2004 | 11:15 AM
psi420's Avatar
Apexi AVC-R can be adjusted by gear.
I think its a good one, I dont have one, but would like to.
Old Apr 12, 2004 | 11:28 AM
Dr Pooface's Avatar
Default Re: (psi420)
I believe the AEM EMS can do speed/rpm boost adjustments as well.
Old Apr 12, 2004 | 11:30 AM
jeremy.'s Avatar
Default Re: (Dr Pooface)
does the profec b do it also?
Old Apr 12, 2004 | 11:32 AM
PM-Performance's Avatar
Default Re: (ek_jeremy)
no the Profec doesnt . The World Electronics is a nice piece, but costly. ut you get what you pay for
Old Apr 12, 2004 | 11:33 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">I believe the AEM EMS can do speed/rpm boost adjustments as well.</TD></TR></TABLE>
Correctamundo. Speed, RPM, Gear, as well as throttle position
Old Apr 12, 2004 | 01:15 PM
TheShodan's Avatar
Moderator
Blitz SBC ID also has gear-based boost as well as speed-based
Old Apr 12, 2004 | 01:24 PM
vtec.dc2's Avatar
Default Re: (TheShodan)
if not too complitated of a question.. but how does it tell what gear? not aem, but gear based boost controlller.
Old Apr 12, 2004 | 01:35 PM
TurboJesse
Guest
Posts: n/a
Default Re: (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">if not too complitated of a question.. but how does it tell what gear? not aem, but gear based boost controlller.</TD></TR></TABLE>
Im not 100% sure but im guessing its based off mph @ a certain rpm.
Old Apr 12, 2004 | 01:36 PM
graphic's Avatar
Default Re: (Mpir3)
what would one need to make the aem boost controller function work???
would i need to already have an electronic boost controller???
Old Apr 12, 2004 | 01:38 PM
AVATAR's Avatar
Default Re: (boost-stupid)
World
Innovative
AVCR
AEM EMS
Motec
Blitz (I guess . . . I'd never heard that)
Old Apr 12, 2004 | 01:56 PM
TurboJesse
Guest
Posts: n/a
Default Re: (AVATAR)
If your on a budget and have hondata you can run a dual stage turbo xs bc and by using the nitrous controls activate the second solenoid to open @ a specific mph.
Old Apr 12, 2004 | 03:09 PM
Kataku2K3's Avatar
Default Re: (Mpir3)
Innovative MSBC or MoTeC
Old Apr 12, 2004 | 10:31 PM
jeremy.'s Avatar
Default Re: (Kataku2K3)
so i'm guessing the avcr is the cheapest out of all of them
Old Apr 12, 2004 | 10:46 PM
Arturbo's Avatar
Better than steak
25 Year Member
Autronic too.
Old Apr 13, 2004 | 06:06 AM
Scott - 93HB Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Blitz SBC ID also has gear-based boost as well as speed-based</TD></TR></TABLE>
Ya, if you get the PowerMeter-iD add-on. It actually reads it off your speed sensors so it's speed dependant boost, in block ranges - which is like gear dependant boost.
Old Apr 13, 2004 | 06:29 AM
MilanoFury's Avatar
I'm pretty sure it runs from your clutch switch, and turbo smart has a gear based boost crontroller i just bought one haven't put it on yet .
Old Apr 13, 2004 | 07:42 AM
Kataku2K3's Avatar
Default Re: (Crazy18)
Yea, every time the gear selection wire on the Innovative MSBC sees 12V+ it brings you up on your next stage of boost. If it's on a street car (where the clutch switch is still working as it did from the factory) I normally just use a relay to reverse the polarity and you're set.
Old Apr 13, 2004 | 07:55 AM
g2turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, every time the gear selection wire on the Innovative MSBC sees 12V+ it brings you up on your next stage of boost. If it's on a street car (where the clutch switch is still working as it did from the factory) I normally just use a relay to reverse the polarity and you're set. </TD></TR></TABLE>
So on the street does the innovative work very well. It seems it would have no idea if you are clutching for an upshift or downshift and therefore not sett correct boost levels for the corresponding gear
Old Apr 13, 2004 | 08:44 AM
Kataku2K3's Avatar
Default Re: (g2turbo)
There actually is a street setting on it but we never use it. We normally just turn down the 5th gear (last setting) boost level and let it stay there if you want to race someone on the street and need traction. You can manually select a gear too so if you want to do a roll on in say third then increase 4th and 5th you can do that too. I think it's more fun to just run full boost all the time and light up 5th tho
Old Apr 13, 2004 | 08:52 AM
DIRep972's Avatar
Smarter than you
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">If your on a budget and have hondata you can run a dual stage turbo xs bc and by using the nitrous controls activate the second solenoid to open @ a specific mph.</TD></TR></TABLE>
has anyone done this yet? thats a cool idea.
Old Apr 13, 2004 | 08:54 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost-stupid &raquo;</TD></TR><TR><TD CLASS="quote">what would one need to make the aem boost controller function work???
u can use a GM boost selenoid..
Old Apr 13, 2004 | 08:55 AM
lbz34's Avatar
Default Re: (DIRep972)
I am trying to find the right gera based controller.
You say the Innovative works on cluthc switch. The Hondalogger can display what gear the car is in. Can the Innovative tap into this wire ( i am assuming it is on the trans somehwere) and use it for gear selection?? I would think the clutch switch would give problems driving daily. Wrong stage, 10 psi in 4 th gear, etc....
Old Apr 13, 2004 | 09:06 AM
vtec.dc2's Avatar
Default Re: (Mpir3)
Im not 100% sure but im guessing its based off mph @ a certain rpm.</TD></TR></TABLE>
that makes sence and it should work.. unless its possible to tap into how ecu reads what gear it is in.
Old Apr 13, 2004 | 09:26 AM
Kataku2K3's Avatar
If Court (uglyasscivic) hasn't changed his setup I'm pretty sure he's still running his with a dual stage triggered by Hondata. It does work well tho unless you're making extremely high horsepower then ramping is also a nice feature to have. As for the gear selection there's really not anyway that I know of, atleast right now to tap into the tranny and to know what gear you're in. I'm sure it is possible as you could just run a series of switches off the interlock or forks but the Hondalogger works off of your rpm/mph and calculates which gear you are in. A manual transmission Honda and ECU do not interpret any signal nor do any calculations to know what gear you are in from the factory. The one switch that is used is for the reverse lights and doesn't tie into the ECU in anyway. You would have to design something like this which wouldn't be too hard then have outputs to a relay. The problem here is if you're working with the Innovative MSBC it only goes up everytime it is hit with 12V+. You'd need a boost controller designed to toggle both up and down from your calculated gear.
