ls turbo
Old Apr 10, 2004 | 10:30 PM
slowr6's Avatar
Default ls turbo
Modified by slowr6 at 4:53 PM 9/1/2007
Old Apr 11, 2004 | 05:45 AM
TurboCoop's Avatar
Default Re: ls turbo (slowr6)
I have a B18B1 and I got a T3/T04E 60 trim w/ .63 AR turbine from cheapturbos.com, but I think I should have gotten one a little smaller. It gets full boost (7psi) at around 3900rpm, and it doesn't let off at all up to 7K. It is a good turbo for the $550 I paid for it, even though it might be a little big. I was thinking about getting a precision turbo, but I didnt have the money at the time.
Old Apr 11, 2004 | 09:28 AM
Ls-Rturbo's Avatar
Default Re: ls turbo (jdog1277)
i got the T3/TO4 60trim w/.63 ar on my Ls and ya it is a bit big but i would chose the same agion. once it is spooled up it dont really stop like when u shift it will drop to like 5psi but go right back to 7 in a fraction of a second and full boost dose come around 4000rpm's but when ur racing u shouldent be at 4000 anyways. oh btw im only boosting 7
Old Apr 11, 2004 | 09:36 AM
mildly.interesting's Avatar
I've got a T3/T4 .63 .60 on my B18A, and it comes on around 4 grand, and pulls 14 lbs all the way to 8K. I do have Arias 8:5.1 pistons and Crower H beams though, but the compression is a little lower than stock....
Old Apr 11, 2004 | 10:08 AM
slowr6's Avatar
Old Apr 11, 2004 | 12:17 PM
slowr6's Avatar
Old Apr 11, 2004 | 12:26 PM
b16ahybrid's Avatar
Default Re: (slowr6)
It depends on what your going to use the car for.
If your going to be driving it daily and want fast spool your going to want a smaller turbo, if your more concerned with getting your 12 sec time slip that will be a good turbo.
You need to factor in your driving, hp goals and your set-up into the equation.
Old Apr 11, 2004 | 01:18 PM
B18bEK's Avatar
i have a stock turbo LS .. XS engineering T04x. i made 323hp 270tq @12.5psi. i mainly use mine for street / highway but i don't think i'd have any problems running mid-low 12's
Old Apr 12, 2004 | 06:03 PM
slowr6's Avatar
Old Apr 14, 2004 | 03:01 PM
TurboCoop's Avatar
Default Re: (B18bEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">i have a stock turbo LS .. XS engineering T04x. i made 323hp 270tq @12.5psi.</TD></TR></TABLE>
Hey B18bEK - What kind of fuel system and tuning are you running to get that much HP with a stock LS engine. I am looking for around 320HP only when I want to turn up the boost, but I thought I'd have to spend a lot to build up the internals my B18B1? Can you give me any info?
Thanks
Old Apr 14, 2004 | 05:19 PM
Alchemist's Avatar
anyone here have experience with the 50 or 57 trim on a B18b?
Old Apr 14, 2004 | 05:59 PM
GDM Z28's Avatar
Default Re: (Alchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alchemist &raquo;</TD></TR><TR><TD CLASS="quote">anyone here have experience with the 50 or 57 trim on a B18b?</TD></TR></TABLE>
yes! i use to have a 50 trim t3 turbo on my ls (for sale if you want it) there was no boost lag and it held its breath all the way to redline. now i have a t3/t04e 60 trim and with my 3" exhaust i hit full boost around 3500rpms i believe. not too much lag at all (atleast it doesnt feel like it) if you have ?'s pm me.
Old Apr 26, 2004 | 12:19 AM
TurboEH2's Avatar
Default Re: (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">
yes! i use to have a 50 trim t3 turbo on my ls (for sale if you want it) there was no boost lag and it held its breath all the way to redline. now i have a t3/t04e 60 trim and with my 3" exhaust i hit full boost around 3500rpms i believe. not too much lag at all (atleast it doesnt feel like it) if you have ?'s pm me.</TD></TR></TABLE>
hey paul this is jason, that 50 trim posted above is all u need. plenty of boost and spools quick
bb6guy
Nov 24, 2009 05:47 AM
Fuzion
Nov 25, 2003 07:03 PM
es four
Jan 21, 2003 11:45 AM
imonkie
Nov 24, 2002 08:31 PM
eddie1681
Feb 25, 2002 09:52 PM
