Detonating still....
Old Apr 9, 2004 | 10:32 AM
Shocka1998LX's Avatar
Default Detonating still....
Okay, my setup is as follows: d16y7 with 50k miles, greddy 15g turbo, big intercooler, stock timing, only running 0.5 bar of boost, 93 octane gas, colder plugs (2 steps) gapped to 0.030, msd external coil and distributor cap, rc engineering 440cc injectors, walbro 255lph pump, safc-2 low throttle set to -40% across the board, and high throttle set to -35% across the board... and today I added the MSD BTM, I put it on the highest amount retardable and still detonating. It's getting enough fuel. I don't know whats wrong.
Please input your device. Thanks
Old Apr 9, 2004 | 11:11 AM
Default Re: Detonating still.... (Shocka1998LX)
ttt
Old Apr 9, 2004 | 11:34 AM
ITSTOCK's Avatar
AFC hack=junk
i detonated all the time with the afc hack junk, it finally blew the motor then i got smart and sold that POS, now running uberdata
Old Apr 9, 2004 | 11:41 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shocka1998LX &raquo;</TD></TR><TR><TD CLASS="quote">Okay, my setup is as follows: d16y7 with 50k miles, greddy 15g turbo, big intercooler, stock timing, only running 0.5 bar of boost, 93 octane gas, colder plugs (2 steps) gapped to 0.030, msd external coil and distributor cap, rc engineering 440cc injectors, walbro 255lph pump, safc-2 low throttle set to -40% across the board, and high throttle set to -35% across the board... and today I added the MSD BTM, I put it on the highest amount retardable and still detonating. It's getting enough fuel. I don't know whats wrong.
Please input your device. Thanks</TD></TR></TABLE>
Damn.. Do you have a wideband o2 to check what your air/fuel ratios are.. Also look at your plugs to see what they look like.. With all the stuff you have there you might have forgotten the most important item in your setup http://www.wbo2.com.. Its $430 or so dollars and its the best investment you can make..
Shocka1998LX
Apr 21, 2004 03:34 PM
Shocka1998LX
Apr 4, 2004 02:55 PM
b16ahybrid
Apr 30, 2003 08:41 PM
p0gi
Jan 19, 2003 05:47 PM
mod5
Jul 23, 2002 07:35 AM
