Oil light problem
Old Apr 9, 2004 | 06:03 AM
B18Flip's Avatar
Default Oil light problem
For some reason my oil light came on last night after driving around...i checked the oil level today and its fine (actually a tab over the top mark) but i'm still getting a solid oil check light. I tried looking through past threads and the possible causes are: 1) low oil level 2) clogged oil pickup 3)bad oil pump...... any more?
number one is out because the level is fine, two i'm doubting because i recently installed a new oil pan during the install not even 1k miles ago. So is it a bad oil pump??? I don't have an oil pressure guage but i'll try to get one to see if i'm getting any pressure at all. PLS help
Old Apr 9, 2004 | 06:08 AM
yellowturbo's Avatar
you could bought a oil pressure gauge tool... its is made to screw it in the T ( that you probably have ) at the back of your engine... were you get the oil for your turbo oil line...
this way you wont have to install a new gauge...
Old Apr 9, 2004 | 06:56 AM
B18Flip's Avatar
Default Re: (yellowturbo)
cool thanks, i hope the local shops have them around....
Old Apr 9, 2004 | 10:49 AM
B18Flip's Avatar
Default Re: (B18Flip)
Ok i'm 99% sure it's the oil pump now......i took off the oil feed from the "T", cranked it over for a few seconds, and there was no oil coming out of the hole at all . What would cause the oil pump to go bad???? The car is a 2001 and only has about 51K on it, less than 1k boosted miles...........
Old Apr 9, 2004 | 11:33 AM
Muckman's Avatar
Moderator in Chief
Wow I hope you didnt drive around like that for too long.
It could be a clog. Or the oil pick up could be too close to the oil pan like on American Hotrod.
Old Apr 9, 2004 | 04:51 PM
blueturbo4door's Avatar
Default Re: (Muckman)
double check your wire to the stock sensor too.
Old Apr 9, 2004 | 09:34 PM
B18Flip's Avatar
Default Re: (blueturbo4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueturbo4door &raquo;</TD></TR><TR><TD CLASS="quote">double check your wire to the stock sensor too.</TD></TR></TABLE>
yup checked it and it was ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Wow I hope you didnt drive around like that for too long.
It could be a clog. Or the oil pick up could be too close to the oil pan like on American Hotrod.</TD></TR></TABLE>
yeah, i'm hoping that's the case LOL. I'd rather unclog the pickup or bang out the oil pan than having to replace the oil pump
Old Apr 9, 2004 | 10:42 PM
lazerus's Avatar
sounds like you trashed a pump
Better take it off whil the motor is still (probably) good!
Old Apr 10, 2004 | 06:33 AM
B18Flip's Avatar
Default Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you trashed a pump
Better take it off whil the motor is still (probably) good!</TD></TR></TABLE>
i'm hoping it still is....luckily the oil light came on right as i pulled in the drive way so i just shut it off right then. Anyone have a good oilpump, timing belt, waterpump and tensioner laying around? I might as well do those too while i'm at it
Old Apr 17, 2004 | 05:15 PM
B18Flip's Avatar
UPDATE: Ok she runs fine now and the the oil system is okay (crosses fingers). the problem wasn't really a bad oil pump. A piece of metal (probably a shaving from taping the oil pan and not cleaning the pan well enough after) got lodged in the bypass valve in the oil pump and held it wide open .
EDIT: big thanks to flamenco-t for hooking my up with the extra lines and tee for the oil pressure guage and Autobahn Tuning Solutions in Norwalk for doing the work
itzyaboyzeem03
Jul 1, 2016 04:40 PM
IBriaIN
Feb 27, 2011 08:28 PM
PeakBoostSi
Oct 14, 2009 04:14 PM
integra_94
Aug 31, 2004 09:10 PM
GruvyTune
Jul 9, 2004 07:16 AM
