oil pressure
Old Apr 9, 2004 | 08:06 AM
scatuli's Avatar
Default oil pressure
about what should the oil pressure be on a b18a1 at idle and in boost?
thanks chris
Old Apr 9, 2004 | 08:24 AM
ExVtec's Avatar
Default Re: oil pressure (scatuli)
bump..also for a b16a2....
Old Apr 9, 2004 | 08:32 AM
showtymers619's Avatar
* B A N N E D *
Default Re: oil pressure (ExVtec)
i thik in low 40 and 60 in boost
Old Apr 9, 2004 | 09:14 AM
gdrum's Avatar
Default Re: oil pressure (ShowTymers619)
anythign above 60 should have a restrictor in boost correct.??
Old Apr 9, 2004 | 09:15 AM
yellowturbo's Avatar
is it normal that when I start my engine the pressure jump to 80 psi ?
Maybe because my oil is cold...
Old Apr 9, 2004 | 10:39 AM
darylfiend11's Avatar
Default Re: (yellowturbo)
damn.... this is scatuli but at idle im around 20 psi then in boost i think im at approx 60-80
so does anyone remember that nissian guy who made the restrictors?
Old Apr 9, 2004 | 10:48 AM
warwagon's Avatar
yeah with my r pump i used to pull like 80 lbs on full load
but now on my y7 i get like 60 max and like 10-15 with no load
Old Apr 9, 2004 | 11:05 AM
ExVtec's Avatar
I am getting around 20psi once warmed up @ idle and around 70psi on boost.
99 Si.
Old Apr 9, 2004 | 11:09 AM
ok i was just making sure, but would you still recomend a restrictor. the only thing im conserned about is that sometime the oil psi will get down to 15 at times.
Old Apr 9, 2004 | 11:10 AM
USDM 4G VTEC's Avatar
Default Re: (warwagon)
Honda engines run aboit 10 psi oil pressure on idle
and they need to see around 50 psi around 3k rpms
all engines i have seen for honda follow this rule
and btw, oil pressure is high when engine is cold and oil is cold
once it gets a lil warmer and softer, it looses pressure..
plus, oil pumps are supposed to be opening their releif valves around 75-80 psi anyhow..........
Old Apr 9, 2004 | 11:27 AM
99B16Si's Avatar
when i first start my car when its cold itll stay at around 80psi. then when it warms up fully ill have about 25psi at idle(900rpm) and it will go up to about 83psi then the valve will open and it will fall back to about 78psi and stay there until vtec where it falls ~10psi instantaneously. it will also climb maybe 1 or 2psi per 1000rpm all the way to redline.
my oil pressure line is T'd off my ls/vtec line also
Old Apr 9, 2004 | 11:40 AM
Default Re: (99B16Si)
does anyone know the guy who made the oil restrictors? if so post it up
thanks
Old Apr 9, 2004 | 11:50 AM
hpfsi's Avatar
Default Re: (darylfiend11)
Oil restrictors - here ya go
Old Apr 9, 2004 | 01:32 PM
scatuli's Avatar
Default Re: (hpfsi)
YES... that is the one thank you!
sikpupy
Oct 13, 2018 07:03 PM
Rooftop voter
Jun 28, 2007 05:47 AM
budget
Apr 25, 2005 06:50 AM
LSVTEC 91 Civic
May 25, 2004 05:56 PM
USDM 4G VTEC
Sep 3, 2003 08:26 PM
