any comments on this T3 60-1
Old Apr 8, 2004 | 02:49 PM
Nextelbuddy's Avatar
Default any comments on this T3 60-1
i can get a t3 60-1 straight garrett turbo for 550 bux. it is used and has only 10 track days on it was not on a daily driver just a track car.
the specs are .72 a/r on the compressor side and .82 a/r on the turbine side.
is this a good turbo to get? i was going to get sc61 but its like 750 everywher and on back order.. any comments? as far as the turbo and price?
Old Apr 8, 2004 | 04:35 PM
Default Re: any comments on this T3 60-1 (nextelbuddy)
bump.. i need to know so i can buy it before its gone if it is good
Old Apr 8, 2004 | 06:59 PM
Bontke's Avatar
I am guessing you plan to run it on the setup in your sig. This is a big turbo for a b series. IT will take a while to spool. I local guy here has an SC61 with .60 a/r on the compressor and .63 a/r on the exhaust and it spools to full boost at 5200 rpm on his B18B. I think that is a bit late. I like to see boost max around 3500-4000 RPM on street cars. Another thing you should do is do a complete calculation on your engines volumetric efficency and find the right compressor map for your setup. I used this site to figure out mine for my B20Z: http://www.gnttype.org/techare....html MY setup calls for a super 60 wheel or a t4 60 trim sheel. It will be different for your car because you have vtec and will shift at higher rpms tham I will. In my opinion, the turbo is too big and the only reason I would buy it is if I knew I could make a profit on reselling it.
Old Apr 8, 2004 | 07:19 PM
HYBRID_H@TCH's Avatar
Default Re: any comments on this T3 60-1 (Bontke)
I have damn near the same turbo on my ride..made 536 whp and 375 wht at 26 psi.
Old Apr 8, 2004 | 08:14 PM
ndogg's Avatar
Default Re: any comments on this T3 60-1 (99Hybrid_Hatch)
sounds big... what are your goals? thats not that killer of a price either. you can get an sc61 for 650 shipped if you look harder. i did. are you sure that garret even makes a .72 AR tubine? i looked and couldn't find one.
Old Apr 8, 2004 | 08:21 PM
Default Re: any comments on this T3 60-1 (ndogg)
ok i found a sc61 for 650 brand new 650 shipped.
specs are:
Compressor:
to4e 60 trim
Turbine:
t350 76 trim .63ar
Old Apr 9, 2004 | 06:29 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">ok i found a sc61 for 650 brand new 650 shipped.
specs are:
Compressor:
to4e 60 trim
Turbine:
t350 76 trim .63ar
60 trim? or .60 a/r?
Old Apr 9, 2004 | 06:41 AM
Default Re: any comments on this T3 60-1 (CivicRyda2k)
hmm i dunno those are the specs i was given
Old Apr 9, 2004 | 06:45 AM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">
60 trim? or .60 a/r?</TD></TR></TABLE>
Its .60a/r Marc, i just wrote it wrong...Its my turbo
Old Apr 21, 2004 | 01:16 PM
H22accord624's Avatar
Default Re: any comments on this T3 60-1 (NextelBuddy)
I am looking for a turbo for my H22a. Which would be the best?
Old Apr 21, 2004 | 02:33 PM
Sonny's Avatar
Default Re: any comments on this T3 60-1 (H22accord624)
I think this turbo would do the trick and the price is right:
http://store.yahoo.com/cheaptu....html
Sonny
Old Apr 21, 2004 | 02:35 PM
alloutmotor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22accord624 &raquo;</TD></TR><TR><TD CLASS="quote">I am looking for a turbo for my H22a. Which would be the best?</TD></TR></TABLE>
how much power u looking to make...and how effecient do u want the turbo to be....ect
Old Apr 21, 2004 | 02:43 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bontke &raquo;</TD></TR><TR><TD CLASS="quote">I like to see boost max around 3500-4000 RPM on street cars</TD></TR></TABLE>
Sorry, but why? So you can melt the tires off 1000 RPM's sooner, and still not fall out of boost like you would with a big turbo?
alperx
Jul 2, 2011 11:18 AM
cpl rampage
May 12, 2009 04:47 AM
boywonda
Aug 18, 2005 12:43 PM
dan_w_82
Dec 14, 2004 09:24 PM
mrbsponge
Jul 21, 2004 06:01 PM
