..Just got back from the machine shop; motor setup inside with 20 pix! :)
Well after 3 months my head and motor are finally done.
I got a .5mm bore for the over sized pistons
They decked block
Blanced crank, pistons, rods, wrist pins
Welded in the block guard
Then port and polished the head, U grind and Milled it was well.
Any how here are the pics; I just though Id share them with you guys. I know they say it should go in apperance, but this was motor work not bling bling or sounds.
I also snapped a few pictures of the dads mustang; I few ppl wanted to see some other pics of it so here they are
And.....(it keeps going) For anyone that bought or planned on buying that D1 fuel rail; he redisgned with some rice words (Fuel Rail). Anyhow thast another story....Thanks for looking
::Hopes it doesnt get locked up::
b16
polish/balanced crank
civic type r crank pulley
acl bearnings
eagle rods w/arp fasteners
cp 9:1 81.5mm pistons
itr water pump
ls/gsr/itr oil pump
Race Eng. Block Guard
AEBS Head Studs
port polish head
supertech valves (dished top, black nitrate coding)
supertech retainers
supertech springs
gsr cams
skunk2 cam gears
obd0-obd1 conversion harness
p28 ecu
uBerdata
D1 fuel rail
DSM blue top 450cc injectors
Whole motor gasket set (oem; stone)
Thats what I got so far....I just need to get the turbo now
There are a few motor pics and mustang pics; just check out
http://www.wamail.net/~nick/motor/
Thanks guys.....next step; the turbo componets...
Modified by jdmjerk at 3:22 PM 4/9/2004
Modified by jdmjerk at 3:53 PM 4/9/2004
They decked block
b16
acl bearnings
itr water pump
ls/gsr/itr oil pump
AEBS Head Studs
port polish head
supertech retainers
supertech springs
gsr cams
skunk2 cam gears
p28 ecu
uBerdata
D1 fuel rail
Re: ..Just got back from the machine shop; motor setup inside with 20 pix! :) (0x64)
i just noticed i have a stud missing from my intake side of the head...errr; oh well probably cheap fix
Re: ..Just got back from the machine shop; motor setup inside with 20 pix! :) (ndogg)
Sup nDogg; Its finally done
Im very aware of the dangers of a block guard; my machine shop backs those guards up 100%. Theyve made well over enough power to believe in them (20+ motor setups with them). I read up on a lot of things to do with block guards; and If you have a machine shop install it properly IT WILL work out for the better. Dropping a block guard in is not the way to go.
With this setup I want at least 350whp. If I can hit 400whp Ill be very pleased. I want to try it around 14~15psi. If they motor still seems to hold well; and I grew some ***** over time; Ill crank the psi up to 20 or so. Im still learning all of the turbo dos/donts; Ive read alot of posts but Im having a hard time believing in my stock sleeves. But everytime I see cheese frogs setup.....I feel like cranking the boost up....hehe any how; thanks guys
Re: (liveforphysics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liveforphysics »</TD></TR><TR><TD CLASS="quote">Its your choice, but are you at least aware of the dangers of block guards?</TD></TR></TABLE>
and what dangers are you thinking about?? tons of peopel run them with no problems
Re: (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">and what dangers are you thinking about?? tons of peopel run them with no problems</TD></TR></TABLE>
He's talking about what he read on the Internet that was posted about someone by someone else's friend's cousins' brother's mom's kid.
Re: (HatchbackComeback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchbackComeback »</TD></TR><TR><TD CLASS="quote">
He's talking about what he read on the Internet that was posted about someone by someone else's friend's cousins' brother's mom's kid.</TD></TR></TABLE>
That right there is why I make myself look stupid when I talk cars with the mechanics. You dont know who to believe on the computer. You dont know if its a 12 year old kid; or a 25 year old that knows his ****.
When I researched the block guards the main concern with them was the over heating issue. I contacted a few companies (GE, and Race Eng. (the one I have) and they all told me the same things. If you just drop a guard it it WILL restrict the flow of the coolant sometimes. If you weld it in place and drop it down about 1/8" - 1/4" then it will allow a little pocket between the head and the block. For 150 bucks (100 for the guard+50 for labor) I feel it will be a very good investment for extra insurance. Why buy rods like I did or head studs when all I want is 350whp. Everyone has seen tons of motors that are making well over 300whp on stock internals....I bought it and did what I did because I want a reliable dailydriver and track car that has 300+whp. Better to be safe then sorry.
Thanks again for the input guys.
Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">FYI...
you can get the head studs at Ace Hardware.
Just look for the box that says "automotive studs".
Its a 1.25pitch. </TD></TR></TABLE>
LoL too late....oh well though
Re: (chwy_thoj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chwy_thoj »</TD></TR><TR><TD CLASS="quote">is this at your personal shop or is it a local.. how much did all this run you?</TD></TR></TABLE>
what do you mean; the machine shop? I never quote exactly what I paid but for the machine work I paid under 8xx
Modified by jdmjerk at 12:52 PM 4/18/2004
Re: (95240sx2jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Its your choice, but are you at least aware of the dangers of block guards?</TD></TR></TABLE>
If you are talking about coolant flow you don't know what you are talking about. Ever wondered why Honda successfully made millions of closed deck motors? Obviously coolant flow is overrated.
Re: (jdmjerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk »</TD></TR><TR><TD CLASS="quote">
what do you mean; the machine shop? I never quote exactly what I paid but for the machine work I paid under 8xx.xx</TD></TR></TABLE>
no more then 15psi; i have stock sleeves; I dont even know if ill run that much
