Major Problem (weird circumstances)
Old Apr 10, 2004 | 09:42 AM
Downs's Avatar
Default Major Problem (weird circumstances)
Okay, this is my problem. I was getting ready to go to Salt Lake yesterday, and we were already to go. I checked the fluids and saw that I was a little low on oil. So I stopped and got gas, then went to the parts store to get oil. It drove perfect on the way. I bought the oil and put it in and yes I am sure that I bought oil instead of ATF or something else.
On our way to the freeway, the car started burning oil like crazy. Then out of nowhere the car starts missing bad. I couldn't even accelerate hardly it was missing so bad. Well, I get home and realize that the oil part was my fault due to me not pushing the dipstick in all of the way, so it popped out and squirted oil everywhere.
I check the CEL it is throwing three codes. #3, 72, and 71. 3 is the MAP sensor (no missing link). 71 and 72 are cylinder 1 and 2 misfire. Already checked the plugs and the wires. Is it normal for a dizzy to go out like that? Any other suggestions?
TIA
Here is my setup
1998 Civic HX
Garret T3 Turbo
Audi IC and BOV
Vortech FMU
NGK BKR7E plugs (2 step colder)
Aftermarket wires
Modified by Downs at 10:57 AM 4/10/2004
Old Apr 10, 2004 | 06:38 PM
Downs's Avatar
Default Re: Major Problem (Downs)
Up
Old Apr 10, 2004 | 06:56 PM
hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downs &raquo;</TD></TR><TR><TD CLASS="quote"> the car started burning oil like crazy. </TD></TR></TABLE>
Sounds like Turbo seals... began to pump oil into intake- check charge pipe for oil. The misfire and MAP are a result of oil in intake.
Old Apr 10, 2004 | 07:11 PM
Sinner's Avatar
wouldnt hurt to do a compression test.
Old Apr 10, 2004 | 10:17 PM
1fstevo's Avatar
New User
do you see wet oil contamination on any of the plugs? If so, there is your problem.
Old Apr 10, 2004 | 10:22 PM
Retired's Avatar
WEST COAST
Default Re: Major Problem (hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">
agreed
Old Apr 10, 2004 | 10:30 PM
1fstevo's Avatar
New User
Pumping oil into the intake sounds good....but only two cylinders misfiring? Only way to tell is pull the charge pipe out then.
Old Apr 12, 2004 | 08:41 AM
Downs's Avatar
Default Re: Major Problem (Evo Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evo Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Pumping oil into the intake sounds good....but only two cylinders misfiring? Only way to tell is pull the charge pipe out then. </TD></TR></TABLE>
I will check the charge pipe today. I know that the turbo has been leaking a little bit of oil, I have found it in my ic piping. But it is just slight residue. The plugs are black, so I am running rich, but there is no wet oil on them. I will let you guys know what I find.
Old Apr 12, 2004 | 09:03 AM
Downs's Avatar
I check the charge pipe and there is no oil in it. Any other suggections.
Old Apr 12, 2004 | 02:18 PM
1fstevo's Avatar
New User
well, stick the dipstick back, fill up the oil to the proper level, change out to new plugs. Drive it again see if it still does it. If it does, immediately pull out the plugs and see what's on it. Then check oil level. Also while driving, see if there is any unusual smoke coming out of the exhaust system. Report back and tell us what happens.
Old Apr 13, 2004 | 03:02 PM
Downs's Avatar
Okay, this is what I did, checked the compression it was 130,110,130,120. The car has over 100k on it and has had nitrous on it as well. So I know that it is low, but the car has had some tough times. Checked the gap on the plugs, they were fine. I reset my ECU. Then started it up. It ran fine, so I don't know what exactly happened, but letting it sit for a few days helped. I still burn oil under boost and even not under boost. But it may be due to the oil squirting all over under the hood. Thanks everyone for your help.
Old Apr 13, 2004 | 03:20 PM
Jared's Avatar
your rings are killed. dipsticks dont just pop out. you have major blow by.
just.me.ek5
Jan 12, 2009 02:42 PM
soundFX
Jan 7, 2007 05:53 PM
xcerpt
Jul 1, 2006 09:36 AM
bnut510
Sep 6, 2005 03:56 PM
Hoya
Mar 7, 2004 06:46 PM
