CEL #5..
Old Apr 8, 2004 | 11:24 PM
cu3tip's Avatar
Default CEL #5..
Sup guys..recently installed a turbo kit on my car..and im running a vortech FMU with the missing link...I'm throwing a CEL 5...don't know why..I've tryed getting new O rings.. didnt work, swapped out my map sensor...didnt work..still getting this code which is causing me to run REALLY rich....and I get nothing when boosting... help help help!! I also checked all my vacuum lines too..they seem to be good..what should i do!!!......I am also running on stock injectors, and stock fuel pump...if that helps with some diagnostics......
thanks guys ...some help would greatly be appreciated..
Old Apr 8, 2004 | 11:29 PM
Silverbeast's Avatar
Default Re: CEL #5.. (cu3tip)
What ECU? What car?
I know there is one in your sig, but the more info, the better.
Old Apr 8, 2004 | 11:33 PM
Joseph Davis's Avatar
Default Re: CEL #5.. (Silverbeast)
MAP sensor too low... Make sure the wiring didn't get damaged or something. I think you're in limp home mode if you run too rich, solid CEL, right? DON'T boost on it until you get rid of that CEL.
Old Apr 9, 2004 | 11:08 AM
cu3tip's Avatar
98 GSR....solid CEL light...yes... how do i get rid of it!! i've tryed everything I can think of....plus on my A/F gauge...it is all the way over to RICH with only one bar...doesn't even move...what should i do!! please
Old Apr 9, 2004 | 01:11 PM
cu3tip's Avatar
bump
Old Apr 10, 2004 | 02:25 PM
cu3tip's Avatar
bump......helppppp
Old Apr 10, 2004 | 11:28 PM
Default Re: (cu3tip)
Well, what in regards to your MAP sensor have you tested? Details.
vt_hokie2008
Apr 29, 2014 11:42 AM
asianspeed
Mar 15, 2003 12:07 PM
00 Si
Jul 5, 2001 01:38 PM
