Will this be ok?
Old Apr 8, 2004 | 02:38 PM
tolowhb's Avatar
Default Will this be ok?
This is the drain flange I am going to be using on my greddy kit. Now the bolts that I need to use to hold it on there are much smaller than the holes in the flange will this pose any problems? Here are the pics, let me know what you think!
Old Apr 8, 2004 | 02:41 PM
dirtySOHC's's Avatar
Default Re: Will this be ok? (tolowhb)
cmon man...now you know it aint gonna work. go to the hardware store and buy some that will
Old Apr 8, 2004 | 02:54 PM
tolowhb's Avatar
Default Re: Will this be ok? (dirtySOHC's)
What about it wont work? Those bolts are the ones that fit in those threads (they came with my greddy kit) What should I get thats diffrent? Thanks!
Old Apr 8, 2004 | 03:05 PM
99B16Si's Avatar
as long as they thread in and are tightened down with the correct gasket u wont have a problem
Old Apr 8, 2004 | 03:13 PM
tolowhb's Avatar
Default Re: (99B16Si)
Yeah, I thought they were plenty long enough. I was just concerned with the width, I dont need leaking down there!
Old Apr 8, 2004 | 03:26 PM
5STAR3's Avatar
Default Re: (tolowhb)
get a freakin washer.
or a bolt with a larger haed.
Old Apr 8, 2004 | 03:36 PM
tolowhb's Avatar
Default Re: (envision2teg)
I have no problem getting a bolt with a bigger head or a washer. I just wanted to make sure everything else with this would be ok.
Old Apr 8, 2004 | 04:07 PM
tolowhb's Avatar
Anymore suggestions?
Old Apr 8, 2004 | 04:13 PM
sporkcrx's Avatar
I dont get what the hell you're asking.
Old Apr 8, 2004 | 04:14 PM
tolowhb's Avatar
I was wondering if the fitting will shift at all since the bolts are not snug in the holes.
Old Apr 8, 2004 | 04:23 PM
-16V-'s Avatar
LOL, just slap that s#$T on already....
Worried huh?
Old Apr 9, 2004 | 08:47 PM
dfoxengr's Avatar
Default Re: Will this be ok? (-16V-)
get a metal bushing made that the OD is the same as the ID of the flange holes. the ID is the same as the bolt OD, and the height is the same as the flange is thick, or thinner...
Old Apr 9, 2004 | 10:30 PM
lazerus's Avatar
Default Re: Will this be ok? (hybridvteceg)
its going to seal fine, make sure its FLAT, and use a nice high quality sealant up in there. I preffer the Indian cheif Gasket sealer by permatex.. It's very high quality.
You seal around the center hole, not the bolt holes. So if its flat, and you use a little high quality sealer, it will seal fine.
DraconicPenguin
Oct 30, 2005 06:13 PM
brad98_teg
Mar 23, 2005 05:47 PM
illicon2003
Jul 11, 2004 11:08 AM
swrdply400mrelay
Aug 5, 2003 04:28 PM
