Just Got a weird Garrett t3; help!!...Pics inside
I picked up a Garrett t3 today from a friend. it is a .42/.48 After i got home and was able to check it out a bit, i noticed it was not your typical t3. After doing some research, im thinking this is off of a mercedes.
first off...what the hell? what kind of flange is this on the compressor side and where can i find one?
Next....how about this flange...isnt the lower right bolt a bit out of place to be a standard t3?
Next....yet another strange flange...where can i find it?
Shouldn't this be connected to something? i cant imagine the wastegate rod not being connected to anything.
If anyone can offer any insight that would be fanatastic. TIA
Alex
Alex
Re: Just Got a weird Garrett t3; help!!...Pics inside (MrCivic98)
Yes, You've got an oddball turbo. Is there any name tag or part number on the turbo? If so, you have a chance to identify it. Call one of Garrett's distributors with the part number and see if they can come up with something. See http://www.turbobygarrett.com for a list of distributors. However, it is likely that if you want to use that turbo, you will be making custom flanges...
Re: Just Got a weird Garrett t3; help!!...Pics inside (RyanCivic2000)
That is teh wastegate actuator arm ,it conects to the actual wastegate which it is missing. Also that is a standard 5 bolt T3 exhaust flange, now the inlet flange, that i couldnt tell you.
that looks like a turbo i started to pull off a dodge charger one time at a junkyard.. had that same flange on the compressor, and the exhaust housing, doesn't have a "built in" internal flapper (internal wastegate)its actually on the exhaust housing on the car..
so check that out, dodge charger.. forgot what year tho, it was pretty old
Re: (warwagon)
That's the Dodge 2.2/2.5 turbine housing, but the compressor doesn't look like the ones I am familiar with. The actuator looks like the Dodge unit, too.
Got any numbers off the CHRA?
Re: (J. Davis)
thats off a Dodge 2.2L non-crossflow turbo. From an 89+, the earlier models were mitsu units, and some VNT ones.
You're missing the downpipe/02/wastgate housing
Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus »</TD></TR><TR><TD CLASS="quote">thats off a Dodge 2.2L non-crossflow turbo. From an 89+, the earlier models were mitsu units, and some VNT ones.
Wrong, the Mitsus came on automatic transmissioned cars. You got plenty of Dodge 2.2/2.5 w/ T3 before '89.
Re: Just Got a weird Garrett t3; help!!...Pics inside (project dc2)
Thannk you all so much for all of the replys. Alright, i think i am going to try and work with it,just being that it is a 42/48 and there is NO shaft play whatsoever. The flanges im not too worried about, i guess those can always be custom made. About the wastegate, what can i do about that? unless i just remove that whole section that is still left on the turbo, and run an external wasetgate?
my friends dad ha s a sandrail which is using a Mercedes T3. thing is so bad-***. has an internal b.o.v. and wastegate, which to this day i still dont understand. but if thats a mercedes t3, theyre rare as hell, he tells me.
Re: Just Got a weird Garrett t3; help!!...Pics inside (WangChung)
I have done some more investigation, and im thinking that the turbo is not a mercedes. There is no internal bov. However, im thinking that im going to use it for the project. If i just unbolt that wastegate actuator, and but a dp flange that covers the wastegate hole, can i run an external wastegate being that im missing the actual wastegate?
Re: Just Got a weird Garrett t3; help!!...Pics inside (hulkhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb »</TD></TR><TR><TD CLASS="quote">Considering it only a .42 intake and a .48 exhaust A/R's ditch it and go bigger </TD></TR></TABLE>
or what hulk said hahahahahahaha
Take a look at an early 80's SAAB 900. like ~'80-'85
The housing a/r's match this car.... possibly.
If this where the turbo came from you should look for something larger.
The early '80's SAAB 900 turbo was/is rated to ~160whp...
Jeffrey Atwood
Jeffrey Atwood
They Call Me Bizzare
01-11-2004 02:20 AM
