Max oil pressure to turbo?
I wanted to know what would be the max oil pressure at wot to run to the turbo. I tried to check garrett's website (honeywell, I think) but they didn't have any specifications.
Anyone have a clue?
Anyone have a clue?
Re: Max oil pressure to turbo? (willyboyD16)
According to Maximum Boost, they recommend less. What is less, i don't know, but i know i only run about 25 psi at full throttle to mine. If i'm understanding the book right, they say 5 psi at idle and 25 under load is the minimum.
If you are smoking, and its pushing oil into your exhaust, chances are its too much oil pressure. If you here high pitched squeeling, your starving it of oil, and you better pray you don't here that, cuz by the time you do, you will be hurting
From what i've gathered, less is better.
greasemonkee
08-25-2007 03:46 PM
