D-series Unorthadox pulley on block build....if you balance?
If you balance the pulley with your crank, flywheel..etc, will the dangers of using one be eliminated?
Its for my D16y8, with rods pistons on stock sleeves
thanks
-Rob
thanks
-Rob
Re: D-series Unorthadox pulley on block build....if you balance? (EF8 D-UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8 D-UNIT »</TD></TR><TR><TD CLASS="quote">If you balance the pulley with your crank, flywheel..etc, will the dangers of using one be eliminated?</TD></TR></TABLE>Absolutely not. You still need the shock absorbing ability of a dampner.
Re: D-series Unorthadox pulley on block build....if you balance? (earl)
Earl, on that note, are their any opportunities to use an aftermarket crank pulley (I.e. fluidampr, etc) on a D-Series? I was browsing around and I don't think I have seen an option outside of a good condition OEM pulley.
billard
05-20-2011 10:05 PM
