prepping the motor for turbo, any tips?
I'm going to boost my y7/y8 mini me in a few months. The block has 97k miles and the mini me setup has been running for 12k of those miles. I'm thinking about getting all of these parts installed/replaced: arp head studs, oem headgasket, timing belt, and water pump. For now I don't want to put in forged internals. Is there anything else I should look to replace? The clutch will come after this as well as some kind of catch can setup.
Re: (AbitAvenger)
How long are you going to run this for, before a rebuild or a build up? I had the same setup, mine was over that for miles. Mine isn't my daily though, just a toy, but i sent 15 psi to it. You don't need arp, peace of mind though. Like i said, depends on when you are going to redo it. I was planning to rebuild mine this winter anyway, so i just played with it, and if it blew up oh well. Well it runs like a champ, starting to burn oil though. Compression was decent, they all built to around 215 - 225, but number one hit really low on the first hit. I'm pretty sure my valve seals are fine, as they only have about 10,000 miles on them. A new timing belt would be a great idea though
Re: (coneheadsracing)
The last time I checked compression it was around 185 across the board, but I will check again. I have no plans on building the block. I just want to run 200whp daily driven. With the turbo I am using, I think 8-9 psi will get me to my goal. I already purchased arp head bolts so I am going to use them. The stock headbolts were re-used when I did the mini me so I sure as hell am not going to boost with those still on.
Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">The last time I checked compression it was around 185 across the board, but I will check again. I have no plans on building the block. I just want to run 200whp daily driven. With the turbo I am using, I think 8-9 psi will get me to my goal. I already purchased arp head bolts so I am going to use them. The stock headbolts were re-used when I did the mini me so I sure as hell am not going to boost with those still on.</TD></TR></TABLE>
Good choice
With Forced Induction, if you buy cheap, you buy twice
All I'm doing for my motor is timing belt, valve adjustment, water pump, arp headstuds, headgasket, a basic tune-up, changing transmission fluid, and check the compression to make sure they are consistent And my motor has 194k miles on it Perfect compression too
Good choice
Psychoteen101
03-13-2015 10:27 PM
EFboostedSI
06-26-2009 10:53 AM
