Engine builder's please chime in!
Old Jan 10, 2006 | 04:17 PM
86si's Avatar
Default Engine builder's please chime in!
well i have someone very interested in my old D16A1 block that has been in my shed for 2 years. i never actually took it apart to see how much damage it took the day the HG went and melted the head and some of the block. well turns out the #3 piston took alot of heat and scored the wall up but looks like it can be honed no prob. the others look like they also could have some issues so i am going to replace the set of pistons and rings with a fresh hone job. my question is will the area that was melted have any effect on the sleeve. or HG issues. it looks like it will seal ok since it didn't hurt the sleeve.
BTW they are JG sleeves at 75.5mm
Modified by 86si at 10:41 PM 1/10/2006
Old Jan 10, 2006 | 05:57 PM
onlinehost's Avatar
that is not something i would use but send the pic to jg and they will tell you for sure since they sleeved it
Old Jan 10, 2006 | 06:06 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Engine builder's please chime in! (86si)
those look stock to me
Old Jan 10, 2006 | 06:35 PM
86si's Avatar
Default Re: (onlinehost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onlinehost &raquo;</TD></TR><TR><TD CLASS="quote">that is not something i would use but send the pic to jg and they will tell you for sure since they sleeved it </TD></TR></TABLE>
i hear ya. i just don't want to sell it if it is gonna cause a problem. if i had another block i would just swap everything over.
Old Jan 10, 2006 | 08:36 PM
DRIVENRacing's Avatar
get the block decked, and you should be ok..
Old Jan 10, 2006 | 08:40 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (adSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">get the block decked, and you should be ok..</TD></TR></TABLE>
that looks pretty deep, i think if you decked it that much, youd have to address the piston issue... piston to valve clearance, compression ratio, etc. if you decked it htat much it looks like the piston will stick out of the bore a good bit
Old Jan 11, 2006 | 12:53 AM
EnzoSpeed's Avatar
Default Re: (wantboost)
They look stock to me too. Maybe it's the pic.
Old Jan 11, 2006 | 05:16 AM
86si's Avatar
Default Re: (EnzoSpeed)
i think i may have it welded and decked. see what my machine shop says
redzcstandardhatch
Jan 3, 2010 09:25 PM
babyS2K
Jul 24, 2006 05:47 PM
turbotime
Apr 1, 2006 07:28 PM
turbo sol
Mar 28, 2006 07:41 PM
wHOAlly
Jan 28, 2004 10:15 PM
