Wastegate leak?
Old Jan 9, 2006 | 09:25 AM
StolenTeg's Avatar
Default Wastegate leak?
I have a leak in my wastegate, when i took it off there are black exhaust gases covering half of the flange. So i assume that it leaking at that place, is it possible to use silicone sealant for this or i should get a gasket?
Old Jan 9, 2006 | 09:44 AM
B00STFREAKS's Avatar
Default Re: Wastegate leak? (StolenTeg)
uhh the wastegate gets pretty hot i wouldnt wanna use a silicone base product.
A gasket is the proper way to fix it..
Scroll to the very past thing on this page at very bottom
Old Jan 9, 2006 | 10:38 AM
bubbahatch92's Avatar
Default Re: Wastegate leak? (B00STFREAK)
You can use red high temp silicone if you want to go that route and be fine. I would get a new gasket and use a very thin layer of red silicone on either side of it.
Old Jan 9, 2006 | 12:41 PM
StolenTeg's Avatar
Default Re: Wastegate leak? (bubbahatch92)
Yeah, i went out and brought some red hi-temp silicone gasket maker but has anyone used these on the wastegate flange and how did it work out?
Old Jan 9, 2006 | 12:59 PM
PM-Performance's Avatar
those gaskets blow out too easy. Ive run no gasket and been better off since.
Old Jan 9, 2006 | 01:01 PM
GaRn's Avatar
I am using only Copper RTV sealant(high temp gasket maker) on my WG and it works perfectly fine.. no leaks
Old Jan 9, 2006 | 01:11 PM
boosted_integ's Avatar
Default Re: Wastegate leak? (GaRn)
i'm running high temp gasket maker on my waste gate and it works awsome no leaks
Old Jan 9, 2006 | 02:38 PM
zeroice's Avatar
Default Re: Wastegate leak? (boosted_integ)
i'm running nothing inbetween mani/wg no leak for me
carlos8
Sep 22, 2013 11:35 PM
GWInquisitor14
Sep 25, 2005 11:30 AM
PolyPill
May 10, 2005 12:47 PM
mskibbz-T
Apr 24, 2004 11:36 PM
IloveNewt
Jan 21, 2004 06:20 PM
