I have a tuning MAP sensor question. . .
Old Jan 7, 2006 | 03:35 PM
EGmmBAH's Avatar
Default I have a tuning MAP sensor question. . .
Ok here it goes I have a simple setup GSR on nitrous and a VAFC after getting it tuned when I spray it will throw a check code 3 for MAP sensor, and occasionally it will do it all motor but that is like once in a blue moon. . . Any ideas I have changed the MAP and it still does it and all wiring both engine and AFC is correct??
Old Jan 7, 2006 | 07:46 PM
civicliveit's Avatar
Default Re: I have a tuning MAP sensor question. . . (EGmmBAH)
sounds like it is reading a positive manifold pressure and throwing the code. i dont know if on nitrous applications a missing link is needed but its wortha shot.
Old Jan 7, 2006 | 07:57 PM
b18ccivics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicliveit &raquo;</TD></TR><TR><TD CLASS="quote">sounds like it is reading a positive manifold pressure and throwing the code. i dont know if on nitrous applications a missing link is needed but its wortha shot.</TD></TR></TABLE>
this guy dont know awhat he is talking about, how muh fuel are you pulling, or adding, sometimes if you add or pull too much it will throw a code, get rid of the afc.
Old Jan 7, 2006 | 08:06 PM
mtber's Avatar
Re-check your wiring. If the problem continues, look into un-installing the vafc & get your self a chipped obd1 ecu solution.
Old Jan 10, 2006 | 01:21 PM
EGmmBAH's Avatar
Default Re: I have a tuning MAP sensor question. . . (mtber)
wiring is correct but why would i get rid of the afc. therefore getting rid of my tune and using a chip that will have less then half of the tuning capabilities of an afc???
eggie75
Apr 7, 2008 01:40 PM
Andrewk138
Jan 17, 2008 07:01 AM
h8ted ek
Sep 13, 2007 10:25 AM
philosofy1
10
Aug 26, 2006 07:35 AM
Cimburke23
Sep 13, 2004 05:23 PM
