hole in turbine housing?
I just bought a T3 Super 60 and while checking it out I saw a hole inside the manifold inlet. It is directly across from the internal wastegate hole. The hole has threads in it and I can see the end of one of the turbine housing bolts. The hole itself is the same side as the bolt. Is this normal?
Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 »</TD></TR><TR><TD CLASS="quote">boost tap?</TD></TR></TABLE>
In the turbine? That would be interesting.
Maybe someone tapped it for an EGT probe?
Can you post a pic?
Can you post a pic?
Re: (PM-Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance »</TD></TR><TR><TD CLASS="quote">
Can you post a pic?</TD></TR></TABLE>
whoops.... didn;t read close enough. Oh well
blackeg
Welding / Fabrication
04-05-2006 10:33 AM
DigitalFusion
10-30-2003 10:54 AM
