ticking noise.. what could be the problem
Old Jan 11, 2006 | 06:14 PM
LilCivic04's Avatar
Default ticking noise.. what could be the problem
well i have a fully built d16z6 and im running 750cc injectors. also i have a swirl polish 1mm larger intake valves. i hear some kind of tick, i know its not a stock motor, so it shouldn't sound like one. i did a valve adjustments a few time and still have this tick. my car runs fine and last time i did a compression test i got 175 across the board. i currently have 6k miles on it. could it be lmas? or injector ticking? i only hear it during idle, but when i go cruising i don't hear any type of ticking or anything.
Old Jan 11, 2006 | 08:36 PM
abnaasefmb's Avatar
Default Re: ticking noise.. what could be the problem (LilCivic04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote"> could it be lmas? or injector ticking?</TD></TR></TABLE>
yes, more than likely your injectors. let it idle so you can hear the clicking and take a long socket extension and put one end on you ear and the other on each of your injectors you should be able to hear it real well. if it’s your injectors don't worry about it. my 450's are loud as hell.
Old Jan 11, 2006 | 10:22 PM
mstolars's Avatar
Could be LMAs, I've seen them get stuck and make ticking sounds when not engaged. Do you still hear the ticking when you hit Vtec?
Old Jan 11, 2006 | 10:33 PM
LilCivic04's Avatar
i dont hear anything while im crusing
Old Jan 12, 2006 | 02:10 PM
graphic's Avatar
i have a similar problem. except my ticking speeds up with rpm. does yours? could mine still be the injectors? valves were adjusted. only started making the noise after 750cc install. how do i listen with a socket extension? did you mean a long reach socket?
Old Jan 12, 2006 | 02:35 PM
rudebwoy's Avatar
lost motion assemly or whatever they call them
Old Jan 12, 2006 | 02:58 PM
ak86's Avatar
Default Re: ticking noise.. what could be the problem (graphic)
sounds like ur problem is ur lifters, u said that the sounds speeds up with the engine right? check those i heard its relatily easy to fix just need to take off ur vavle cover and tighten them hmmmm but i dont know
Old Jan 12, 2006 | 05:48 PM
graphic's Avatar
Default Re: ticking noise.. what could be the problem (ak86)
tighten valve lifters?
Old Jan 12, 2006 | 06:00 PM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ak86 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like ur problem is ur lifters, u said that the sounds speeds up with the engine right? check those i heard its relatily easy to fix just need to take off ur vavle cover and tighten them hmmmm but i dont know</TD></TR></TABLE>
WTF? i love how people will just spew out any dumb *** **** that enters their mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilCivic04 &raquo;</TD></TR><TR><TD CLASS="quote">i dont hear anything while im crusing</TD></TR></TABLE>
yeah what ever you want to call it, it an old trick works like a sethascope or however the expletive you spell it.
Old Jan 12, 2006 | 06:15 PM
KeithsDAteg's Avatar
Most healthy Injectors make a "ticking" noise.
Old Jan 12, 2006 | 07:06 PM
LilCivic04's Avatar
Default Re: (KeithsDAteg)
what could happen to my motor if i have damaged lma. how do i check if their bad
Old Jan 13, 2006 | 06:05 PM
LilCivic04's Avatar
bump, i forgot i am running msd 6al and blaster 3. i dont know if that helps
Black-Ty [EG6]
17
Dec 31, 2007 08:53 AM
boomersz
23
Apr 28, 2007 10:43 AM
RockLee`
Oct 10, 2006 09:01 AM
projectac
Jul 29, 2005 07:24 AM
Mr.DC2TurBo
Sep 25, 2003 09:51 PM
